This D44A sucks - Page 3 - JeepForum.com
post #31 of 40 Old 11-22-2013, 11:58 AM
PolkaPower
Originally Posted by xcaliber81 View Post
ok nm i was going off the title lol.
I was wondering how much extra it would add to the cost of an 8.8 if you had to pay for the welding. Most 8.8 set ups are going to be at least a grand minus the fabrication if you can't weld so rebuilding the 44a is certainly cheaper. Enough to want to go that route over an 8.8 which is why I elected to fix mine 2 years ago instead of swapping axles. If it was worse off and the prices were closer then I would have gone with the 8.8 but an extra 400 bucks or more was convincing enough to stay with what I had at the time. Keep in mind there are always other aspects of the ZJ that need fixing as well so trying to spread the money around to as many areas that need fixing is a tricky balance and hey, you can't always get what you want, but sometimes, you get what you need.
PolkaPower is offline
post #32 of 40 Old 11-22-2013, 12:37 PM
speedbucket
I get your point but the 8.8 price is a few hundred high. 8.8s can be found 3.73 all day long. 200$ for the axle and 300$ for a complete bracket kit. If you cant find the right gear ratio it would be around 1000$
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #33 of 40 Old 11-22-2013, 12:49 PM
PolkaPower
Did you look at Johns post with the price breakdown of everything? His axle was 100 bucks and he still spent 1200 not including having it welded. The brackets and axle are not the only thing you need. I wouldn't stick a used JY 8.8 under my Jeep without rebuilding it first. Might as well do a selectable locker while I'm at it as well.
With just the estimate of what his cost and adding the local shop price of 350 for labor, I'd be looking at a ball park figure of 1550 total vs. 750 to rebuild the D44a with the LSD rebuilt. Trust me I checked into all of this 2 years ago.
post #34 of 40 Old 11-22-2013, 02:57 PM
speedbucket
Those numbers are insane. I feel sorry for y'all. I don't have 1550 in my suspension and axles ..with lockers
post #35 of 40 Old 11-22-2013, 03:12 PM
PolkaPower
You probably did all of the fabrication yourself and stole the rest
post #36 of 40 Old 11-23-2013, 09:50 AM
jeeepguy
jeeepguy's Avatar
Originally Posted by theopacific1 View Post
This big aluminum turd is really pissing me off.
My 5.9 sounds like a jet taking off.. AGAIN
when i bought the car a year and a half ago she was howling. i got her rebuild by the guy who works on my commuter turd (kia spectra aka the Mario kart). Its been about a year later and shes howling again, it took about a week to go from great to good lord thats loud. its been about 3 months and it has not got any worse. Also last month i did the nv242 swap and..... well i have been really working the rear diff out.
I have read that aluminum case stretches out over time and rebuilding it is only a bandage till you go broke or trash it.
basically what should i do cus I'm not a fan of spending 800+ every 12 months to stretch out my diff case a little.
what trucks have a cast case?
what is so special about the 44 vs the 35?
Looks like your 5.9 is mainly a street rig. Almost any 44A you get out of a jy at this point will be worn. Since the housing has wear issues, not a good idea to use these any more. Go find a low mileage wrecked Explorer w/an 8.8, 3.73 gears, LSD and disc brakes, clean it up or have it rebuilt and mount under your rig. It will stand up to the 5.9 and will last you until the rest of the rig fails for around the same $800 you'll pay to fix a 44A
A new 44A would be fine but good luck finding one for less than several thousand
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #37 of 40 Old 11-24-2013, 08:06 AM
speedbucket
Here's another reason an aluminum housing sucks....
http://norfolk.craigslist.org/pts/4155236800.html
post #38 of 40 Old 11-24-2013, 09:27 AM
Taz360ZJ
Did you do all the welding yourself?
I had a friend with a shop weld it for me since he was in the slow season. Wanted $70 for the welding including welding the tubes.....I gave him double because his wife was 8 mos preg & they needed the $ for the baby.
I however welded the spring plates on with the mig at work during mock up, pre bed lining & sand blasting.
'94 ZJ Limited 4.0, BB, 31's, the rust free California transplant.
Taz360ZJ is offline
post #39 of 40 Old 11-24-2013, 09:44 AM
sanktheboat
"Axle has great articulation."
Nice.
sanktheboat is offline
post #40 of 40 Old 11-24-2013, 05:54 PM
riot1987
Build thread^^
riot1987 is offline
