post #1 of Old 03-17-2003, 08:08 AM Thread Starter
ILoveto4x4inNC
D44a
I just got a reply back from tractech about lockers for the Dana44a under the ZJs. He said that the reason nobody offers a locker for this axle is that it's prone to twisting. He also said that these axles have a hard time staying alive in stock applications. Has anybody had problems with this rear end? If this axle is such a POS why in the hell did Jeep offer it as a heavy duty option? I'm tempted to swap in a D35 out of an I6 JZ and hope I don't destroy it. I don't have $1500-$2000 to spend on a custom rear axle for my daily driven, lightly off-roaded Jeep. It mostly cruises the highway and goes into the back country during deer season. A selectable locker would be nice to have when in the mud getting to the hunting cabin. Will a D35 suvive behind a V8 equipped JZ? Or am I stuck shelling out big bucks to get a custom rear?
This aint your daddy's Jeep!
'98 ZJ with 5.2L
Stock except for Optima red top
bigger tires(30x9.50 15 BFG MTs)
Rancho RS5000 shocks
swapped in NV231
and Pioneer CD deck.
White Jeep Club member #14
ILoveto4x4inNC is offline
post #2 of Old 03-17-2003, 02:36 PM
Black96ZJ
You'll be fine with a 35 till u get to 35s or somethin huge like that. Alot of V8 jeeps also came with them.
Black96ZJ is offline
post #3 of Old 03-18-2003, 07:25 AM Thread Starter
ILoveto4x4inNC
I posted the same question on that other forum, and I was called a retard for wanting to put a D35 behind a V8. I think I'm gonna try it anyway. I'll just hang on to my 44a in case I destroy the 35. Is there a differance in gear ratios between the 2 axles? Since I'm not going with bigger tires for a while I don't want to regear. Thanks for the input.
'98 ZJ with 5.2L
swapped in NV231
post #4 of Old 03-19-2003, 04:12 PM
RufftyTuffty
RufftyTuffty's Avatar
Don't waste your time with a D35.
Go for a XJ / MJ D44 or a Ford 8.8.
If your going to get into wheelin you wont reget it.
RufftyTuffty is offline
post #5 of Old 03-19-2003, 07:10 PM Thread Starter
ILoveto4x4inNC
Is the XJ axle the same width? I thought the ZJ was wider. If they're the same width I might look into it.
'98 ZJ with 5.2L
swapped in NV231
post #6 of Old 03-20-2003, 04:35 PM
RufftyTuffty
I believe the widths are very close....you might need some 5/8" spacers.
FYI...come over to www.nagca.com
97 V8 TSi 7" RK LA/36s/4.88s/ARBs/TERA 60/8.8/Crane/PSC
post #7 of Old 03-21-2003, 08:02 AM Thread Starter
ILoveto4x4inNC
Also is the D44 in the rear of an XJ a real 44 or is it a POS like what I already have under my ZJ?
'98 ZJ with 5.2L
swapped in NV231
post #8 of Old 03-21-2003, 10:16 AM
RufftyTuffty
It will be an iron D44...just what the doctor ordered
8.8 or D44a in WJ? gatorayde ZJ Grand Cherokee Forum 39 06-19-2012 04:15 AM
d44a vs d44 Mudzilla6661 ZJ Grand Cherokee Forum 30 08-28-2009 07:54 AM
How much for a D44a zjeepin ZJ Grand Cherokee Forum 10 08-19-2009 08:41 PM
D44a or D44 JakeDS ZJ Grand Cherokee Forum 1 04-05-2008 10:34 AM
The D44a SAZJ ZJ Grand Cherokee Forum 4 12-29-2006 12:36 PM
You may not post new threads
You may not post replies
