D30 High Pinion Question - JeepForum.com
post #1 of 6 Old 02-08-2008, 09:45 PM Thread Starter
XJAdventure
1994 ZJ
Will a HP D30 from and XJ (non disconnect) bolt into an ZJ. If not how much work would it require.
XJAdventure is offline
post #2 of 6 Old 02-08-2008, 09:51 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
it is a 99% bolt in, i did it, i had to drill a few holes for ABS retainer cips for the wires and for the lower bump stop extensions.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #3 of 6 Old 02-08-2008, 09:53 PM
WJChris
WJChris's Avatar
Is the benefit of HP that there are more splines to make contact with, thus spreading the load across more area on the Axles....?????
WJChris is offline
post #4 of 6 Old 02-08-2008, 09:55 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
noo....
the drive shaft is up higher and out of the way, and the HP is stronger because of the way the stresses are exerted on the axle... i dont know the exact science.
build thread:
5.9 ANDY is offline
post #5 of 6 Old 02-08-2008, 10:03 PM Thread Starter
XJAdventure
1994 ZJ
Awesome, I figured it was mostly bolt in. Thanks!
post #6 of 6 Old 02-09-2008, 08:35 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
xj's use different attachment style for the sway bar endlinks. you may need a different driveshaft, zj's like cv joints everywhere for some reason.
all brackets are in the same locations though. if you want to retain abs you'll want to use your knuckles, xj non abs knuckles don't even have the boss cast in for the abs sensor.
though abs can be a drawback on the trail anyways.
ratmonkey is offline
Swapping a High PINION D30 into my ZJ hebijake ZJ Grand Cherokee Forum 9 12-17-2009 10:05 PM
Looking for Ford High Pinion dana 60 front Need help eshew ZJ Grand Cherokee Forum 1 03-03-2009 11:28 PM
high or low pinion 30? spidermonkey ZJ Grand Cherokee Forum 2 11-14-2008 11:48 AM
Pinion Seal question DTrem08 ZJ Grand Cherokee Forum 9 04-26-2008 12:49 PM
High Pinion D30 question Lud04X ZJ Grand Cherokee Forum 3 03-28-2008 09:19 AM
