CV's in my ZJ today - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > CV's in my ZJ today
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 03-28-2009, 10:57 AM   #1
97ZJMAN242
CV's in my ZJ today
okay i'm doing my cv axles in my zj today, both sides. what all will i need as far as parts and fluid. that way i can make one run to the auto parts store. to pick up my pcm and everything i need for the axles. thanks guys
97 ZJ. 5.2 Chipped/Short Ram Intake/Flowmaster 40 series/Roof Rack/4 6in hellas facing forward/2 3in facing reverse/Linex'd cladding & bumpers/Cragar Soft 8's/31x10.50x15's/2.25 KOR BB/KOR Rad support/Black Diamond Shocks/All Metal Radiator/JKS Disco's
05 GMC Envoy XL. full Eclipse Components and 15in
drop down screen to replace stock unit....DD
84 Chevy K10 6inch sus. lift, 3inch body lift, 383 stroker, torsion posi, 3.73's.
97ZJMAN242 is offline   Reply With Quote
Unread 03-28-2009, 11:00 AM   #2
97ZJMAN242
also anything else i should think about doing today while i'm under there that i could pick up from the auto parts store.?
Unread 03-28-2009, 12:26 PM   #3
newfieZJ
Jeep collector
newfieZJ's Avatar
Loosen the wheel bolts
jack up at the axle , remove wheel
remove cotter pin and lock from the axle shaft
remove 1 5/16 or 36 mm nut off the axle(you may need someone on the brakes to hold it , a very good chance)
Remove pressure from brakes by squeezing the caliper(this makes removal and installation a breeze .
remove 2 bolts holding the caliper , they are 1/2"
Using tie straps , hang them so they are supported , don`t just dangle them from the lines
remove rotor
Remove cotter pin and nut from the tie rod end , using a hamme , tap the knuckle by the TRE until it drops , ususally 4-5 good taps will do . 3/4" nut on the TRE
remove the three bolts on the rear of the knuckle that hold the wheel brg 13mm 12 point socket or wrench
using a flat head screwdriver , start tapping it next to the top ear of the brg flange using the screwdriver as a wedge . Once separated slightly , repeat this at all 3 ears until you work it out . If you are replacing the brg , a BFH works great and will destroy the bearing .
pull side axle out
penetrating fluid is all you will need
newfieZJ is offline   Reply With Quote
