Quantcast CV to U-joint style drive shaft - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > CV to U-joint style drive shaft
Old 08-19-2008, 07:59 PM   #31
buckwheat
Here's the skinny...new driveshaft cv joint in and now things are shakin quite a bit and don't sound so good. Could be coming from the driver side axle(cv joint) or from the differential?? Could a problem with these have been the reason the driveshaft cv joint failed?
buckwheat is offline   Reply With Quote
Old 03-05-2009, 08:20 PM   #32
AZwaffles
called a local specialty drive shaft shop today and was quoted $250 to have my drive shaft rebuilt and converted to a u-joint. He said i wouldnt need to change anything i will just be able to bolt it back on and be ready to go.
AZwaffles is offline   Reply With Quote
Old 03-05-2009, 08:26 PM   #33
gatorayde
lol, if you're converting something you're obviously changing something (ie: the yoke(s) ). So make sure he knows what he's doing before you let him have at the driveshaft.
gatorayde is offline   Reply With Quote
Old 03-05-2009, 08:31 PM   #34
Virmagicus
Headed Out West
Virmagicus's Avatar
nope ..... they make conversion kits that directly bolt on.
Virmagicus is offline   Reply With Quote
Old 03-05-2009, 09:41 PM   #35
Yardman Harry
O
Yardman Harry's Avatar
I went to the yard and grabbed an XJ Double cardon Ujoint front ds. Then I went to the local pick an pull and grabbed a new pinion yoke off of a ZJ to fit the DS. Getting that bugger off was tough in the yard, luckily somebody had cut a DS in half so I used that as a cheater bar.
I read a crap ton about installing the new yoke into my D30. I read where a couple of guys didnt measure preload, and they have just torqued to 250 ftlbs. and some that take it to shops.
The FSM tells you how to measure the preload, SO... I decided to tackle this myself.
UNFORTUNATELY I didnt have a torque wrench that goes less than 20 inchlbs...
But I did the install anyway, SO FAR SO GOOD... cross my fingers. Everything is holding up great, no vibrations. no noise from the front... yet. We will see.
Was I hesitant on doing the job myself? Yes, but I priced out new D30s at the yard, only about 150 bucks... so.. we will see what happens.
Yard
Edit: Total Cost for conversion:
$50 for the XJ DS
$0 for the yoke
roughly 2 hours to install
The Tcase straps where the DS meets the Tcase uses size 8mm if I remember. Dont use a 12pt wrench, use the 6pt socket or else you will have mess on your hands.
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline   Reply With Quote
Old 03-05-2009, 11:47 PM   #36
FPKites
ZJjazzyJim
FPKites's Avatar
Harry, you get the goofiest prices at your junkyards...el-cheapo for a 242, and rape for a driveshaft
If a yard wants more than $35 for a driveshaft, I go on down the road
Jim Karlin
"Duh! Big RED Jeep!!!"
Best mod you'll ever do on ANY vehicle!!!!
FPKites is offline   Reply With Quote
Old 03-06-2009, 12:19 AM   #37
Virmagicus
Headed Out West
Virmagicus's Avatar
Better not have any dings in it !!!
Old 03-06-2009, 07:47 AM   #38
Yardman Harry
O
You can imagine my surprise when I had to buy a new rear DS for the TJ to fit the D44 that I swapped in. $100 for the rear DS!! that thing is like 1ft long!!! i almost pooped!
I picked that TJ DS up at a different yard though. But most of the yards that I usually go to have good prices.
Yard
Hunter Green
White
~Junked~
Old 03-10-2009, 12:05 PM   #39
_Kyle_
Hmmmm....
_Kyle_'s Avatar
Does anyone have any pictures of this conversion installed, and a price? In checked the rockford website and it doesnt seem to want to let me do anything on it.
-Kyle
1996 Grand Cherokee
RIP Troy (bigbluezj94)
1996 ZJ FOR SALE
_Kyle_ is offline   Reply With Quote
Old 03-10-2009, 01:09 PM   #40
FPKites
ZJjazzyJim
FPKites's Avatar
ZAQ123 did it some time ago, I think. He might have some pics.
Jim Karlin
Old 03-11-2009, 01:59 AM   #41
_Kyle_
Hmmmm....
_Kyle_'s Avatar
Photos and any information from anyone else would be great!
-Kyle
1996 Grand Cherokee
1996 ZJ FOR SALE
Old 03-11-2009, 04:49 PM   #42
zaq123
1941 MK Compass
here is the only pic I found
DS looks just like this
http://www.rockforddriveline.com/prop.htm
I think I paid around $180 or so a few years ago and that was a discount price. It fits right into CV cup and can be replaced within 5 min to your old cv setup in case of any emergency/trail repair.
call Rockford and tell them you need propeller shaft for your ZJ.They will tell you how to measure your DS properly if you want it to be a custom fit.
I got already made to OEM size prop shaft for my ZJ and it worked fine with 5" and adjustable CAs. I tried to destroy this shaft many times with my front OX locker and 32"s and it hold up well. I did however had to rebuild TC side of it after a few years of abuse
zaq123 is offline   Reply With Quote
Old 03-11-2009, 04:52 PM   #43
DothanJeep
Originally Posted by spife7980 View Post
well then *cough* *cough*
/clear throat ...
things i learned today
1. dont post later than 9- becomes delirious.
Night Crew is not for you my friend.
00' WJ 4'' IRO 285 Tire...Ect-SOLD 7/2/2009
98' ZJ STORM TROOPIN' SOLD
97' ZJ with 117K THE DD mi SOLD
01'WJ Project Cheap fix.
DothanJeep is offline   Reply With Quote
Old 03-12-2009, 01:00 PM   #44
_Kyle_
Hmmmm....
_Kyle_'s Avatar
Sweet. Thanks for the info!
As it stands the 5.9 isn't a good test subject without all the parts to complete it soooo i'll see what happens with the 5.2. Rumor is the stock shaft is long enough with the addition of upper adj arms (which i'll have right away when I do the lift).
-Kyle
1996 Grand Cherokee
1996 ZJ FOR SALE
Old 03-12-2009, 03:56 PM   #45
horatio102
Either pull the yokes from a donor, or order the conversion from a vendor.
I got mine from IRO, and it was what, a bit over $400, and a halfrack of Heineken to get it installed.
Pulling the yokes is going to require a puller.
horatio102 is offline   Reply With Quote
Glock Forum
