Quantcast CV to U-joint style drive shaft - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > CV to U-joint style drive shaft
Old 08-13-2008, 06:27 PM   #16
Mike Cooper
I just did the conversion. Bought a u joint style shaft from a 94 GC, and brought it to a local shop to have it shortened to my size. (I tried driveshafts from xj's and gc's, none of them fit the distance I needed, all were to long, From what I hearm they changed the transmissions in later year GC's, causing the distance to be shorter.)
SOLD: 1998 5.9 Grand cherokee: Suspension: 3.5" IRO Lift, JKS Rear Track Bar & Quick Discos, IRO Double shear front track bar, Black Diamond Shocks,33X12.5 BFG Muds, ARB Front Bumper, Home made Rock Sliders, 242 Swap
New Toy:
2007 Wrangler Unlimited. 2" BB, 1 1/2" wheel spacers, 285/70/17 Goodyear Duratracks.
Mike Cooper is offline   Reply With Quote
Old 08-13-2008, 08:47 PM   #17
buckwheat
The drive shaft on the 95 is adjustable and from what I understand, has some room to expand to compensate for thermal expansion. This actually may have been the cause of the cv joint wearing out! It uses a compression fitting with a rubber? washer which decomposed a bit leaving the shaft with too much play...so I think.
Anyway, I'm close to finding a conversion U joint to replace the CV joint that is on the front of the drive shaft...as seen in Dillons photos. I'm learning that the cv joints are notoriously unreliable. There's also a guy on eBay who builds custom drive shafts at a very reasonable price. FYI (CV Restoration Inc.)
buckwheat is offline   Reply With Quote
Old 08-15-2008, 12:36 AM   #18
buckwheat
Striking out on finding a conversion for my driveshaft from cv to u joint without having to change the yoke in the differential! Does anyone know if this exist for the 95 GC v8? This is the most frustrating thing...I can't believe I'm having such a hard time finding this. Is the junk yard my only option?
Old 08-15-2008, 01:03 AM   #19
Mike Cooper
why would you need to change the yold on the dif? Read my post above yours, worked well, and cheap.
New Toy:
Old 08-15-2008, 08:46 AM   #20
FPKites
ZJjazzyJim
FPKites's Avatar
The CV style driveshaft uses a cup-type yoke. As hard as you'd try, you'd never get it to hold a u-jointed shaft.
Jim Karlin
"Duh! Big RED Jeep!!!"
Best mod you'll ever do on ANY vehicle!!!!
FPKites is offline   Reply With Quote
Old 08-15-2008, 10:15 AM   #21
zaq123
1941 MK Compass
unless you get special u-shaft , just like the one I have
zaq123 is offline   Reply With Quote
Old 08-15-2008, 10:22 AM   #22
FPKites
ZJjazzyJim
FPKites's Avatar
That is correct sir - Now I have to search for that PM from you...damn
Jim Karlin
Old 08-15-2008, 10:51 AM   #23
Mike Cooper
Sorry, didnt read it right, I though he said the transfer case end. Yes, I took the yolk right off the same vehicle I got the shaft from, swapped it with the one for the cv joint, no problems at all
New Toy:
Old 08-15-2008, 02:31 PM   #24
buckwheat
Solution found!!! I'm so damn resourceful sometimes! Here's the shizznit...www.Rockforddriveline.com This is valuable info guys...they manufacture CV joints in Illinois. Found exactly what I was looking for...a CV style joint for the front driveshaft and only $112!!...check-em out their catalog has it all. Thanks for all the banter guys, much appreciated
Old 08-15-2008, 03:19 PM   #25
FPKites
ZJjazzyJim
FPKites's Avatar
99.99% sure that Zaq sent me there as well for a u-jointed shaft with an axle end that bolts to the stock yoke. They seem to be good people.
Jim Karlin
Old 08-15-2008, 05:08 PM   #26
platinum5.9
Jeeper
platinum5.9's Avatar
2003 WJ
why not just swap the yolk over and get a driveshaft from the same jeep you got the yolk from?
platinum5.9 is offline   Reply With Quote
Old 08-15-2008, 06:18 PM   #27
Dillonzj
because changing a yolk without the proper know how can destroy your axle..
Dillon
98' JEEP GRAND CHEROKEE LIMITED 5.9
149k 5.9L v8 White
Crane Cam shaft and Crane, Roller Rockers, bored .030 over, edelbrock performer heads, M1 Intake manifold, Fasstman throttle body, magnacore wires, platinum plugs, K&N FIPK, dough thorley headers,3" high flow cat, 3" magnaflow mandrel bent exhaust, SCT tuned
***future mods -5.5 IRO LA - KOR sliders -KOR roof rack -
SOLD-
95' JEEP GRAND CHEROKEE LIMITED
188k 5.2L v8 White 98 ZJ rims
Originally Posted by nashmd454 View Post
...we all know they empty our pockets...yet they fill our hearts...
MY BUILD THREAD
Dillonzj is offline   Reply With Quote
Old 08-16-2008, 09:40 PM   #28
Mike Cooper
How so? From what I was explained, was you need to make sure they are tightened the same. The yolk I took out, and the yolf I put in were the same thickness in the flange, so you just need to make sure its tightened in the same amount down the thread.
New Toy:
Old 08-16-2008, 09:48 PM   #29
Dillonzj
or you could just get a conversion shaft that hooks up the exact same way as the cv style only doesn't have a cv on it...
149k 5.9L v8 White
SOLD-
MY BUILD THREAD
Old 08-16-2008, 10:08 PM   #30
zaq123
1941 MK Compass
this way you actually can keep end reuse your cv shaft as a trail/emergency spare
Glock Forum
