#1 | ||
CV to U-joint style drive shaft
My front drive shaft has a CV join in it.. my 94 ZJ had a u-joint where it connected to the axle but not my 95.. If I go get a u-joint drive shaft from a junk yard how do I take it out of the axle and what all is required to swap it??
Thanks Diillon here is a pic of mine... ![]() ![]()
98' JEEP GRAND CHEROKEE LIMITED 5.9 149k 5.9L v8 White Crane Cam shaft and Crane, Roller Rockers, bored .030 over, edelbrock performer heads, M1 Intake manifold, Fasstman throttle body, magnacore wires, platinum plugs, K&N FIPK, dough thorley headers,3" high flow cat, 3" magnaflow mandrel bent exhaust, SCT tuned ***future mods -5.5 IRO LA - KOR sliders -KOR roof rack - SOLD- 95' JEEP GRAND CHEROKEE LIMITED 188k 5.2L v8 White 98 ZJ rims Quote:
MY BUILD THREAD |
#2 |
i think with the 249 transfer (which i would assume you have) you are supposed to have the cv. something about the u joints binding to much harming the case? i think thats what i've heard but im not sure.
-James Got to love an ORVIS guy... IRO 5.5", Front LA & Double Sheer TB, Rear Adjustable SA and TB, JKS Quick Discos, DT8Ks 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs JCR Stage 2 Sliders, IRO Trans Skid |
#3 | |
yes this is true for the half shafts that power the tires.. but I am wondering about the actual Drive Shaft that powers the axle
MY BUILD THREAD |
#4 |
Headed Out West
Wrong CV spife ... Dillon is referring to the CV driveshaft.
Jeff |
#5 |
Headed Out West
To remove the U joint type you just have to remove the 4 bolts that go into the yoke.
Jeff |
#6 | |
do you know how it comes out of the axle?
because i cant connect that type drive shaft to my axle.. mine has the wrong type yoke sticking out of it...
MY BUILD THREAD |
#7 |
then you have to replace the yoke.
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds |
#8 | |
haha i need to know how
![]() Thanks Dillon
MY BUILD THREAD |
#9 |
well then *cough* *cough*
/clear throat ... things i learned today 1. dont post later than 9- becomes delirious.
#10 |
ZJjazzyJim
You can get a yoke for a u-joint conversion from a donor XJ. You can also get the driveshaft from said donor. It's actually very smart to do when going above 3-4" lift height.
Be careful not to mess up the pinion preload when you take out the yoke. Best to have a driveline shop do the yoke swap for you.
Jim Karlin "How the heck do you get there?" "Duh! Big RED Jeep!!!" Best customer service in the states: Best mod you'll ever do on ANY vehicle!!!!
#11 | |
so I cant take the yoke out myself.. or if I can how do you remove it?
MY BUILD THREAD |
#12 |
my 249 has a u-joint DS and it works fine.
1993 Jeep ZJ. 4.0 |
#13 | |
ZJjazzyJim
As does mine.
#14 |
Yo!
Any luck DillionZJ? My '95 GC just blew out the cv joint that youre talking about (to the axle) and trying to find a replacement has been tough! I can't seem to find it seprate from the drive shaft (DS=$790.00 at dealer!!!wtf!) Someone recommended doing the conversion you're talking about but changing out the yoke to do so sucks. Does anyone know where to find just the lobro894 cv joint?? Other than a junk yard....thanks! |
#15 |
Jeeper
I've owned a 95 with a 249, and a 98 with a 249 and both had the u-joint style shaft. I was shocked when I got under the 5.9 and saw the same style dillion has. I didnt think they had that in 95.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
