Cv shaft passenger side - Page 3 - JeepForum.com
post #31 of 44 Old 04-22-2013, 01:16 PM
tucsonzj
recycle? some companies have a core when you buy them online so you can send back the broken for them to do remans on. As for the pop, are you sure it's the CV or hub? Someone will correct me if i'm wrong but It could be your track or sway bar.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #32 of 44 Old 04-22-2013, 03:53 PM Thread Starter
cryptic3
What's the track or sway bar? Can anyone tell me what this is? As I did some investigation at work and it looked a little loose
cryptic3 is offline
post #33 of 44 Old 04-22-2013, 04:17 PM
kg6mov
Hears the voices
kg6mov's Avatar
That is the lower control arm.
kg6mov is offline
post #34 of 44 Old 04-22-2013, 04:20 PM Thread Starter
cryptic3
Thank you!!!!! Life safer. How do I fix the lower control arm... As it looks like its going to fall off do I need jack stands?
cryptic3 is offline
post #35 of 44 Old 04-22-2013, 04:48 PM
tucsonzj
what do you mean it looks like it's gonna fall off? is it loose? wiggles? details man, details.
tucsonzj is offline
post #36 of 44 Old 04-22-2013, 04:57 PM Thread Starter
cryptic3
It wiggles but not much could move it like a centimeter. Sorry....
cryptic3 is offline
post #37 of 44 Old 04-22-2013, 05:01 PM
kg6mov
Hears the voices
kg6mov's Avatar
Does the bushing look damaged at all, cracking, crumbling, missing?
To replace the control arm you'll need a jack, stands, torque wrench, etc. You might be able to do it lifting only one side up, but I would think it near impossible to get the arm off and the new one in. You really need to get the fornt wheels off the ground and then support the axle.
kg6mov is offline
post #38 of 44 Old 04-24-2013, 09:05 PM
jabba974
If you can wiggle that control arm easily, I would say the bushings are shot...Replace them, or the whole control arm...I think a replacement control arm is around $50-$60.... bushings might be cheaper yet...
jabba974 is offline
post #39 of 44 Old 04-24-2013, 09:40 PM
chetzar
1994 ZJ
Control arm replacement is easy, and you can do it without lifting the vehicle off the ground, but having it on a jack stand and the tire off makes the job easier. If you do replace them yourself, you will need an alignment done after to correct the caster.
chetzar is online now
post #40 of 44 Old 04-24-2013, 09:48 PM Thread Starter
cryptic3
I tightened the the bolt twice but it jeeps getting loose and I hear the rattling so I guess I might have to replace the control arm. However I'm not sure where to put the jack stand, how much an alignment caster will cost on average?
cryptic3 is offline
post #41 of 44 Old 04-24-2013, 09:50 PM
capcyclone
capcyclone's Avatar
And I would suggest replacing the entire arm as opposed to just the bushings. I'm doing this soon - I've ordered some arms and am waiting for them to arrive. I've never swapped them on my ZJ, but I helped a friend replace just the bushings once - and it is a royal PITA. You can buy OEM style arms at A1 (an entire set of 8 for around $200). Otherwise, I think Rock Auto has decent prices on stock arms as well.
And of course, there's always Kolak - who gives good advice and prices.
"The Jeep is America's only real sports car" - Enzo Ferrari
'98 Jeep GC 5.2L "ZJ" - Sold
'02 Jeep GC 4.7L HO "WJ" - Daily driver
capcyclone is offline
post #42 of 44 Old 04-24-2013, 09:54 PM
kg6mov
Hears the voices
kg6mov's Avatar
Careful, the 1aauto CA's i got didn't fit on the rear. Great for the front though.
kg6mov is offline
post #43 of 44 Old 04-24-2013, 10:00 PM Thread Starter
cryptic3
[QUOTE="capcyclone;15344685"]And I would suggest replacing the entire arm as opposed to just the bushings. I'm doing this soon - I've ordered some arms and am waiting for them to arrive. I've never swapped them on my ZJ, but I helped a friend replace just the bushings once - and it is a royal PITA. You can buy OEM style arms at A1 (an entire set of 8 for around $200). Otherwise, I think Rock Auto has decent prices on stock arms as well.
And of course, there's always Kolak - who gives good advice and prices.[/QUOTE
I don't think I don't need a step by step guide (I don't think) but where would I put the jack stand as I feel I would damage the drive shaft
cryptic3 is offline
post #44 of 44 Old 04-25-2013, 09:42 AM
capcyclone
capcyclone's Avatar
Here's a quick pick of a jack point that should work for you.
