Cv shaft passenger side - Page 2 - JeepForum.com
post #16 of 44 Old 04-19-2013, 08:49 PM Thread Starter
cryptic3
So I looked at the link with the tutorial. Do I need to also purchase a wheel hub? Or is that just if I'd like?
cryptic3 is offline
post #17 of 44 Old 04-19-2013, 08:53 PM
kg6mov
Hears the voices
kg6mov's Avatar
Don't need to replace them, but do a shake test, it's not a bad time to do it if they're going.
kg6mov is online now
post #18 of 44 Old 04-19-2013, 08:55 PM Thread Starter
cryptic3
Good advise.... What is a shake test
cryptic3 is offline
post #19 of 44 Old 04-19-2013, 08:58 PM
kg6mov
Hears the voices
kg6mov's Avatar
With the wheel off the ground put your hands at 3 an 9 and try to shake the wheel, it shouldn't move at all. If it does try again at 12 and 6 watching the ball joints. If it still shakes it's the wheel hub. If it only shakes at 3 and 9 it's likely a TRE of steering.
post #20 of 44 Old 04-19-2013, 09:07 PM Thread Starter
cryptic3
OK I will try that thanks.
cryptic3 is offline
post #21 of 44 Old 04-20-2013, 12:39 PM Thread Starter
cryptic3
OK so u got all my tools and when time to take off tire I came across a problem one just one if the lug nut is stripped I'm using a cross iron and I used 19 on all of them but that last one and a 17 is to small
cryptic3 is offline
post #22 of 44 Old 04-20-2013, 12:54 PM Thread Starter
cryptic3
Never mind just looked it up and I have to back a smaller socket and use my torque wrench
cryptic3 is offline
post #23 of 44 Old 04-20-2013, 01:02 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
never, ever use a torque wrench to remove a bolt or nut. they're not designed for that use. ratcheting ones go in reverse for left hand threaded fasteners.
the torque on the hub nut is important. it can be the difference between 100k of service life and 10k of service life.
stock lug nuts that don't have the outer cladding on them are 18mm.
ratmonkey is offline
post #24 of 44 Old 04-20-2013, 04:18 PM Thread Starter
cryptic3
Hey guys just a friendly update I my CV axle was shot to hell got my brand new one in now! I ran into another issue omg but now I found this thing I'm pointing out is stripped and my bolts won't tighten anyone know what this thing is call so I can see how much it is and or what is an easier fix? I thought about finding a slightly bigger bolt
cryptic3 is offline
post #25 of 44 Old 04-20-2013, 04:24 PM
kg6mov
Hears the voices
kg6mov's Avatar
You've stripped the caliper mount on the knuckle. Knuckles are a pain to replace. I don't know if there is an easier solution, but knuckles are cast so they can be hard to modify.
post #26 of 44 Old 04-20-2013, 04:26 PM
durango-bob
2006 WK
That is your caliper slide bolt and you cannot install a bigger one since if it a fairly tight fit in the caliper slider. You have two options - replace the knuckle or install a heli coil to resore the threads. I had that happen on mine but didn't find it until I had finished welding and resurfacing the divots in the pad contact areas. (I see you have some divots that need attention, too.) So I installed a heli coil. Takes about 3 minutes, just drill it out, tap it, and install the heli coil and break off the tab.
durango-bob is offline
post #27 of 44 Old 04-20-2013, 06:31 PM Thread Starter
cryptic3
OK hold up Durango Bob your like Jedi master and I'm still a padawan. I'm learning I'm interested what these divot you speak of that need attention. And I found a quick fix. I used same size bolt just slightly longer and used a nut and tightened it that way... Just a quick but not permanent solution as this is my dd so I'll look into how much it cost to replace or maybe this helicoil kit you speak of
cryptic3 is offline
post #28 of 44 Old 04-20-2013, 10:10 PM
jabba974
You might want to check Dorman/motormite..they may have a single oversize caliper bolt for that...I know they did for a buddys dodge....is it possible to retap the threads?
jabba974 is offline
post #29 of 44 Old 04-21-2013, 01:21 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the divots are the areas worn into where the brake pads rest. as they get worn you end up having the pads hang up on them and you get uneven braking and excess pad wear.
have you put the wheel on yet? there's very, very little clearance between the knuckle and the brake rotor for a nut.
most people have found that regular heli-coils back out over time in a through hole application like this. the proper bet is a heavy wall threaded insert, like a keensert, and use a high strength metal locking compound(like loctite 609),
dodge, chevy, and many ford calipers will accept oversize thread slide bolts because they're put together in a much different manner than the jeep units we have.
post #30 of 44 Old 04-21-2013, 06:26 PM Thread Starter
cryptic3
I managed to get the nut on and tighten it..... I ran into something else after replacing the CV Axel I still hear a popping sound in the area of where I replaced the CV Axel but not like before when it was constant just like once when I hit a bump or something like that anyone know what it could be? It runs really smooth now just that little issue with hitting a bump in the road. Oh and what can I do with my old CV
cryptic3 is offline
