Quantcast CV joint to U-joint swap completed! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > CV joint to U-joint swap completed!
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 07-26-2008, 01:36 PM   #1
arveetek
My 93 JZ with 249 TC came stock with CV joints in the front axle. They were both in bad shape and made clicking noises when turning. After wheeling for the 1st time, the right had joint gave out.
Lucky for me, I have a buddy who has a spare ZJ for parts with u-joint shafts in the front axle. He said I could have them if I pulled them out. So, I was able to pull the whole front shaft assemblies out, including the hubs, so that saved me a step.
It took me literally 20 minutes to pull my old shafts and probably 15 minutes to install the new u-joint shafts. (It took me longer to pull the u-joint shafts out of the parts jeep....the bolts were pretty well stuck.)
Thanks to this thread:
http://www.jeepforum.com/forum/f310/how-replace-axle-shaft-wheel-hub-bearing-assembly-w-pics-377208/
The whole job went really easy. I jacked up the front end, popped the wheels, brake calipers, and rotors off, removed the three bolts on the backside of the knuckle, and pulled the shafts out. Very, very simple.
Now I have u-joints in the front, and after hard wheeling at Disney, OK, this past weekend, I didn't break anything and I have no more clicking noises!
I was going to get pictures of the swap, but I was in a hurry and didn't take the time.
Thanks for the great info and help ya'll!
Casey
1997 Wrangler TJ, 2.5L LO, 5 speed, RC 3.25" lift, Skyjacker shocks, 31's, Lock-Right locker in front, Bestop 2-piece Hardtop
arveetek is offline   Reply With Quote
Old 07-26-2008, 05:25 PM   #2
j.love
1994 ZJ
If you still have the 249 in there you might run into binding problems, 249's don't like universal axle shafts.
David.
94 ZJ laredo 5.2 V8 soon to be 5.9!!
In Delaware, the largest growth of population is Indian Americans, moving from India. You cannot go to a 7/11 or a Dunkin’ Donuts unless you have a slight Indian accent. I’m not joking. Joe Biden
j.love is offline   Reply With Quote
Old 07-26-2008, 05:28 PM   #3
CLNinja
yeap ^^^^ like said above
the ZJs with the 249 TC came with CV shafts for a reason... you might run into binding with the ujoint shafts... and you most likely will have vibes from them
[color="#003300"]Matt[/COLOR]
[color="white"][CENTER][size="1"]
[url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url]
[/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B]
[SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER]
CLNinja is offline   Reply With Quote
Old 07-26-2008, 08:49 PM   #4
Sporer65
Location: Powder Springs, Georgia/University of Tennessee
I doubt you would run into any problems running u-jointed shafts with the 249 case. It isn't like with a 242 the u-joints aren't rotating at all and the owner's manual says that with a 242, you can run in Full Time 4WD all of the time if you wanted to, so the u-joints must not cause a problem then.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
GA Trail Riders
Sporer65 is offline   Reply With Quote
Old 07-26-2008, 09:25 PM   #5
arveetek
No problem for me....I do have the 249 but this Jeep rarely sees over 25 mph! Vibes are not an issue, and wheel hop when turning is no big deal when playing on the trails.
This is a trail-only rig.
Casey
Old 07-26-2008, 09:38 PM   #6
j.love
1994 ZJ
Casey
Well then, congratulations on the mod!
David.
Old 07-26-2008, 09:39 PM   #7
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
The 249 and u-jointed front axle shafts are fine. Some vehicles came stock from the factory with this combo, you will be fine.
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote
Old 07-27-2008, 05:45 AM   #8
ratmonkey
Living dead mod
ratmonkey's Avatar
they will bind up on sharp turns. trust me.
ratmonkey is offline   Reply With Quote
Old 07-27-2008, 08:30 AM   #9
Virmagicus
Headed Out West
Virmagicus's Avatar
Doesn't it mostly show up on asphalt ? That was my impression with a few of the ZJ owners here on the forum. This is a trail rig, I think some washers to limit FSL would not hurt and he would be just fine.
Virmagicus is offline   Reply With Quote
Old 07-27-2008, 01:51 PM   #10
Casper4x4
nice i am gonna be doing this swap this up coming week i think, thats for the post! Would you care if i hit you up for more questiosn though?
Alonzo "Casper" Gonzalez
1993 Jeep Grand Cherokee Laredo
4.0L Engine w/ 231 TC
IRO 4.5" Lift on Kumho 31" MT
IRO frnt adj. track bar w/ mount
Bilstein 5150 shocks
JKS Quick Disconnects
JCR 1 Ton steering
Addco Front Sway bar
Flowmaster muffler
K&N air filter
2 Pro Comp 2 KC lights on KOR light bar
Coleman roof rack
Coming Soon! Gears and locker!
Casper4x4 is offline   Reply With Quote
Glock Forum
