CV boots - JeepForum.com
post #1 of 3 Old 03-13-2003, 11:37 AM Thread Starter
ILoveto4x4inNC
CV boots
Do ZJs normally go thru a lot CV boots or is there a problem with mine? I'm gonna need to replace my boots again shortly, this will make the 3rd set in a year. Is this normal? At this rate I'm tempted to switch over to u joints. Is that a viable option? Please help as this is getting frustrating.
This aint your daddy's Jeep!
'98 ZJ with 5.2L
Stock except for Optima red top
bigger tires(30x9.50 15 BFG MTs)
Rancho RS5000 shocks
swapped in NV231
and Pioneer CD deck.
White Jeep Club member #14
ILoveto4x4inNC is offline
post #2 of 3 Old 03-13-2003, 05:01 PM
Stocker
sounds fishy...
Just had the OEM cv boots replaced on my '95 ZJ; they lasted 8 years. Got ones from NAPA put on, & they darn well last more than a few months! Yours should definitely last longer. Where are you getting them? You may want to try OEM boots next time. If mine wear out soon that's what I will be doing.
One reason they wear out (IMO) is they flex a lot, and with a ZJ's very tight turning radius, they flex A LOT! BTW, this is also why I don't think you could or should try to use u-joints instead. The angle is simply too great to allow their use.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #3 of 3 Old 03-13-2003, 07:26 PM Thread Starter
ILoveto4x4inNC
These are ones that the dealer put on.
'98 ZJ with 5.2L
swapped in NV231
Cv Boots bbhockey19 ZJ Grand Cherokee Forum 6 08-07-2008 09:50 PM
Tie rod end boots. Windowsrookie ZJ Grand Cherokee Forum 6 05-09-2008 02:44 PM
Tie Rod boots kwb18 ZJ Grand Cherokee Forum 9 08-13-2007 09:22 PM
CV Boots?!?! mattklaman ZJ Grand Cherokee Forum 8 11-09-2005 03:26 PM
ZJ CV Boots seanounorman ZJ Grand Cherokee Forum 7 08-04-2005 07:26 PM
