CV Axle and Bearings or Axle Only??? - JeepForum.com
post #1 of 4 Old 08-30-2013, 08:18 PM Thread Starter
tahoe9813
It looks like my front pass CV boot is shot. The driver's is good, but I'm going to go ahead and replace them both.
Since I'm going to disassemble everything, I was wondering if I should just go ahead and spring for the wheel bearings at the same time.
The car (97 ZJ Orvis) has 173k miles on it.
Thanks for the $0.02.
Ben
tahoe9813 is offline
post #2 of 4 Old 08-30-2013, 08:29 PM
Kkash920
if I was you I would highly recommend changing them with the cv axle! its a very very common problem check your you joints to
Kkash920 is offline
post #3 of 4 Old 08-30-2013, 09:40 PM
zarnold
Ben
With that kind of mileage, most definitely! Your probably going to want to replace the hub assembly.
http://www.discountbodyparts.com/cat...cid=productads
zarnold is offline
post #4 of 4 Old 08-31-2013, 12:05 AM
jabba974
Might as well...you don't want to have to do the job again in a month...
jabba974 is offline
axle , bearing , cv
