Cutting dash to access heater core??? - JeepForum.com
post #1 of 12 Old 10-14-2013, 03:24 PM Thread Starter
congerz83
congerz83 is offline
post #2 of 12 Old 10-14-2013, 11:47 PM
Oldfrog
2007 WK
No safety goggles. Brilliant.
Yeah....I want this guy working on my Zj.......NOT !
Darwin award.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 12 Old 10-15-2013, 05:04 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Looks like he was well on his way to doing it correctly too,before the cutting wheel came out.
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
Originally Posted by HighLonesome
coralman is offline
post #4 of 12 Old 10-15-2013, 09:02 AM
Jeeples
Jeeples's Avatar
Once you get to that point it's not much work to remove the rest of the dash and replace the core the proper way. If you're not replacing the AC evaporator core, then you don't need to disconnect the lines through the firewall. You should be able to just pull the HVAC box back a couple inches in order to replace just the core.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Build Thread
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is online now
post #5 of 12 Old 10-15-2013, 07:30 PM
Rikoshay
It's been a loooong time since I've taken a dash apart to fix a heater core (knock on wood).
But one thing comes to mind; when a vehicle is built the entire dash assembly is pre-assembled, radio, wiring, gauges, everything. They just slide the whole assembly in with a long arm and put in a couple bolts, hook up the wires and away it goes. Only takes 30 seconds or so and it's done.
Haven't put a whole lot of brain power into how you could pull the entire dash back out that way. Just thinking.
Rikoshay is offline
post #6 of 12 Old 10-15-2013, 08:35 PM Thread Starter
congerz83
I'm not saying I would do it, but I am intrigued to know how much time he's actually saving.
post #7 of 12 Old 10-15-2013, 09:12 PM
zjosh93
Not much if any: it looks like the dash is already loose, the hole looks too small to pull the core through, and the video ends before we see any progress to the core.
zjosh93 is offline
post #8 of 12 Old 10-15-2013, 10:14 PM
ieattacos
Cant wait to see his video on changing a trani filter
ieattacos is offline
post #9 of 12 Old 10-15-2013, 10:22 PM
riot1987
Ive THANKFULLY.... never had to do a heater core. But Im all for opening 'er up to get more access. In his case Its all going to be covered afterwards. Im not sure how essential it was to cut, but if it helped get to some bolt heads or something then hell, id probably do the same. Ive changed many a fuel pump by cutting holes in the trunk as opposed to dropping the tank.
http://www.jeepforum.com/forum/f22/riots-97-grand-1436100/
Build thread^^
riot1987 is offline
post #10 of 12 Old 10-15-2013, 10:34 PM
rlcii77
I just replaced the heater core in a 5.9 ZJ and there's no way I'd suggest cutting on the dash or anything other than the coolant hoses, if you're gojng to be replacing them... There's two coolant hoses, around twenty screws, a few bolts and ten or so electrical connectors to disconnect, then the dash has room to be pulled away from the firewall enough to remove the entire HVAC assembly, if needed... The entire process took me about 6 hours, and there was nothing difficult about it... I think the most difficult thing about it was getting the coolant return hose off the old brass heater core outlet... lol
'94 Limited ZJ (CRUSHED, kept the 5.2L, 46RH & 249 TC)
'96 Orvis ZJ
'98 Slate 5.9 ZJ (DD)
rlcii77 is offline
post #11 of 12 Old 10-15-2013, 11:13 PM
StPaul59
Unfortunately the camara was destroyed during an attempt to change the batteries..
StPaul59 is offline
post #12 of 12 Old 10-16-2013, 04:11 AM
coralman
coralman's Avatar
StPaul
coralman is offline
