Cutlass Death Wobble UPDATE! READ - JeepForum.com
post #1 of 21 Old 07-15-2011, 10:10 PM Thread Starter
Cutlass
1994 ZJ
Okay well some may know i have been fighting death wobble for 3 months now!
I have researched it to no end, my fathers a mechanic and we cannot fix this problem...
I have replaced:
Tie rod
TRE's
Track Bar
Upper/lower ball joints
Wheel Hub Assembly
All new lower control arm bushings
Tires dynamically balanced and rotated
Front end alignment (1/8th Toe-in 5* caster)
and put on a $90 steering stabalizer to mask it somewhat but if anything made it worse (MOOG SUPER TRAIL BOSS)
I HAVE NO IDEA WHATS LEFT!!!!!!!!!! Iam contemplating selling the damn things thats how frustrating its been.
1994 Grand Cherokee V8.... R.I.P Black ZJ
IRO/RC 4.5"
33" Dunlop A/T's
Built Not Bought #520
Cutlass is offline
post #2 of 21 Old 07-15-2011, 10:14 PM
johnridesjeeps
Upper control arm bushings?
johnridesjeeps is offline
post #3 of 21 Old 07-15-2011, 10:16 PM Thread Starter
Cutlass
1994 ZJ
nop have not done the uppers cant see why that would cause any front end issues as the uppers arent really known for that but who knows. i just cant see dumping more money into this thing and not fixing it...GRRRRRRR
IRO/RC 4.5"
33" Dunlop A/T's
Cutlass is offline
post #4 of 21 Old 07-15-2011, 10:23 PM
johnridesjeeps
Yea,that's pretty much the only thing you didn't mention, hah. When those other items were replaced, were the round bolt holes messed up to more of an oval shape? Just thinking even tho stuff is new, maybe there's still some slop. You try the obvious of some one turning the wheel back and forth while someone is under the front end looking for any time of play?
post #5 of 21 Old 07-15-2011, 11:11 PM
badbird17x
badbird17x's Avatar
1994 ZJ
My 98 developed this bad months after the lift, then I put street tires in it and it started doing in everytime I got to 35, even on gravel. I took it to the alignment shop and it hasn't done it since. The very large Chevy dealer in Fargo aligned my dmax 3 times telling me everything is perfect until I personaly showed them that my rears where an inch closer in the front than the rear, with a tape measure, then they said yea your right your axle tube is bent. Try another alignment shop, by the way my grand has over200000 on it with all stock bushings.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #6 of 21 Old 07-16-2011, 12:09 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Well upper bushings are often a cause.
motor mounts cause a similar experience.
Rear bushings can cause it.
bad tires can cause it.
Bad steering box
You've really only scratched the surface.
ratmonkey is offline
post #7 of 21 Old 07-16-2011, 12:12 AM
CherokeeGT
check your front u joints! your runnin out of parts up front hehe
CherokeeGT is offline
post #8 of 21 Old 07-16-2011, 05:05 AM
mudruna
1994 ZJ
mine is still doing this too, been chasing my tail for the past few months. I think my next thing to check is the steering box, it is the only place I get any play. I might also change the front upper bushings, they looked fine when I changed the UCA's but again they are the only bushiungs I haven't changed.
94 ZJ Limited- 7" IRO premium, 4.56 gears on Elockers and Chromo's, 35" claws on beadlocks, Kevin's sliders
mudruna is offline
post #9 of 21 Old 07-16-2011, 01:18 PM Thread Starter
Cutlass
1994 ZJ
steering box is good, i got my tires balanced and rotate them frequently they are not bad enough to cause my issue. motor mounts wouldnt cause my death wobble... if it was motor mounts it would stop after braking slightly and they woulkd have to be so lose to actually casue any issue and what rear bushings are you talking about?
IRO/RC 4.5"
33" Dunlop A/T's
Cutlass is offline
post #10 of 21 Old 07-16-2011, 02:04 PM
NapsterZJ
I'd definitely get the upper control arm bushings replaced. I've seen people replace these bushings and have had their DW disappear because the bushing was so FUBAR'd.
my .02 cents...
1995 ZJ Laredo 4.0 - 5 Speed swap and 4x4 conversion, JKS KOR conversion and durometer bushings, Bilstein 5100s, fixed LCAs
DD - Stock 99 WJ 4.7 QD with flo 40
NapsterZJ is offline
post #11 of 21 Old 07-16-2011, 05:06 PM
gothchick
Rear upper and lower CA bushings - Rear track bar bushings... Might check sway bushings while you're under there.
Jack up the rear - Use a crow bar to gently pry the CA's & track bar at the bushings. If they move in a way they're not supposed too, you got bad bushings.
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #12 of 21 Old 07-16-2011, 08:30 PM Thread Starter
Cutlass
1994 ZJ
alright il definately look into the uppers il drop em down tomorrow and see whats up. its just annoying throwing money at "maybe's". i think doing the uppers will be the last thing i replace or else il scrap it and start over, its getting to the point were its not worth my time and struggles when grands are so common...but i do love mine haha
IRO/RC 4.5"
33" Dunlop A/T's
Cutlass is offline
post #13 of 21 Old 07-16-2011, 08:56 PM Thread Starter
Cutlass
1994 ZJ
oh and i looked under my truck today after getting it algined yesterday...well since i marked the cam bolt on the control arm with a maker i looked and saw it was in the same spot so the shop didnt touch my caster...fml... exact reason why i do all the work on my jeep..... so i brought back and showed the guy and told him he needs to set it and tht my steering wheel was not straight either... got it back and i havent gotten any issues yet we shall see
IRO/RC 4.5"
33" Dunlop A/T's
Cutlass is offline
post #14 of 21 Old 07-17-2011, 05:15 AM
mudruna
1994 ZJ
He may not have moved the cam because when he put it on the machine it showed that it was in spec, maybe you got it right. The steering wheel not being straight is a big no no for any "good" alignment tech though.
mudruna is offline
post #15 of 21 Old 07-17-2011, 08:33 AM
markt800
hi i'm new here but have cured the worst DW anyone has ever seen. i changed everything i mean everything and had so much smoke blown up my A$$ i'm farting rings for life. the worst thing i did was buying "kevins track bar DW cure" what a joke. he sends you the softest bushings on the market and then charges almost fifty bucks for harder ones. anyhow i'm done talking about my poor investments let me tell you what fixed my DW 100% CURRIE 1 TON STEERING its not cheap but i promise its your problem. please don't put any more money into this problem until you get this steering.
markt800 is offline
Death Wobble RickShane ZJ Grand Cherokee Forum 13 11-13-2011 09:34 AM
50mph wobble-not death wobble zeekracing ZJ Grand Cherokee Forum 7 07-27-2010 07:58 AM
death wobble what to do? drob951 ZJ Grand Cherokee Forum 4 04-28-2009 06:36 PM
Death Wobble Update jnkarrik ZJ Grand Cherokee Forum 50 11-26-2006 08:45 PM
Death Wobble Update Rford ZJ Grand Cherokee Forum 7 10-25-2005 03:42 AM
