i painted mine with some flat black and then later went to gloss, mine i just popped everything off, wiped it down real good with denatured alcohol and self etching primer then 2 coats were perfect for mine. i dont have any pics on my work computer tho when i get to my laptop i can grab you some pics
The transfer case shifter has some plastic tabs melted over on the back. I just took a small flat head and carefully pry and break the melted tabs to take the bezel apart.
On the trans bezel the "P R N D 2 1" part is just held on by some dbl sided tape. Just carefully pry up.
I used some automotive goo adhesive to put everything back together after painting.
I did the 3m wrap, but in a brushed aluminum flavor instead of carbon fiber.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
