Custom front bumpers - JeepForum.com
post #1 of 16 Old 05-12-2013, 07:02 PM Thread Starter
zjforlife
Hey fellow zj owners so next weekend I was going to the scrap yard and I was going to get some metal to make myself a custom front bumper I just wanted to see a few pics of other people's projects and get there opinions also I wanted to know the difficulty of it and how much it would cost in metal I have a welder and have a pipe bender thank you in advanced - David
zjforlife is offline
post #2 of 16 Old 05-12-2013, 08:42 PM
Myusername1674
Google may help ya
In all seriousness though, I wish I had the tools and skills to make a bumper. I really like the look of some of those tube bumpers out there.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #3 of 16 Old 05-12-2013, 09:03 PM
riot1987
Do you have a coper too? Then you can really make some cool stuff. My build has my bumper in it. I made it and it came out ok. Just make sure its solid if you decide to put a winch on it. If I did one again id use more plate and less tubing like I used in my last one
Build thread^^
riot1987 is offline
post #4 of 16 Old 05-13-2013, 04:38 AM Thread Starter
zjforlife
No I don't have a coper but how much did it cost you and can you post a few pics please and what was the difficulty of it?
post #5 of 16 Old 05-13-2013, 06:37 AM
riot1987
Material was easily under 100$ it took two days. It wasnt too hard its one of those things that just takes some time and a trial and error approach. Tack it first.
Build thread^^
riot1987 is offline
post #6 of 16 Old 05-13-2013, 06:38 AM
riot1987
I cant load pics here anymore really JF is ****in with me.. I have more in my build. I like mine but I think it looks a might big personally. I hope it helps though man, for pics check the build thread, but ill try to help answer questions if I can.
Build thread^^
riot1987 is offline
post #7 of 16 Old 05-13-2013, 08:46 AM Thread Starter
zjforlife
Thanks man how does it hold up have you been pulled out by it yet if so how did it hold up? And any tips on it what kind of wielder did you use cause all I have is a 120 will that be able to weld that metal?
post #8 of 16 Old 05-13-2013, 08:53 AM
riot1987
220 is preferred. Just make sure you really burn in your welds. I had my first bumper on an old jeep and tboned a dude goin like 45. It was the same design. It DESTROYED his car. My jeep too but that bumper saved my ***. It held together VERY well. Ive winched from it too and had zero issues with it. I have a lincoln 155. Its a small 220v welder. Love it.
Build thread^^
riot1987 is offline
post #9 of 16 Old 05-13-2013, 10:10 AM Thread Starter
zjforlife
What gage thickness is that steel that you used?
post #10 of 16 Old 05-13-2013, 06:24 PM
riot1987
I used 1/4" for most of it. some non structural pieces were thinner, i Believe my winch mount plate was at least 1/4" if not 5/16"
Build thread^^
riot1987 is offline
post #11 of 16 Old 05-13-2013, 07:30 PM Thread Starter
zjforlife
Man that sucks I can't use a 120 then I would have to use a 220 how did you cut out those holes in your rebar did you use a die grinder? To connect the bumper to the frame I mean what did you use to paint it?
post #12 of 16 Old 05-13-2013, 10:26 PM
riot1987
rebar..?
I used a drill for all my holes and a grinder and band saw for all my cuts.
I primed it and used bedliner
Build thread^^
riot1987 is offline
post #13 of 16 Old 05-14-2013, 09:26 AM Thread Starter
zjforlife
The bar behind the bumper cover I just wanted to know how you connected your metal bumper to that
post #14 of 16 Old 05-14-2013, 09:55 AM
PolkaPower
You don't connect anything to that. You tie it into the frame rails with plates and bolts.
PolkaPower is online now
post #15 of 16 Old 05-14-2013, 10:59 AM Thread Starter
zjforlife
Oh ok thanks guys for all your help I wonder how I'm going to make this work with only a 120v wielder hahah
