currie JJ in an IRO track bar - Page 2 - JeepForum.com
post #16 of 22 Old 04-15-2013, 02:12 PM
speedbucket
ok, so i ordered this stuff on friday from ruffstuff. I had to order another 7/8x7/8 heim to finish parts for my front and rear links as well. I called and talked to Dan, He was nice enough to sub the smaller tube bung into my pair so i could keep my kit discount he was running.
I then had the epiphany that all Ruffstuffs misalingment spacers are for 2" mounting width and IRO's bracket is 1.75". So I called Dan back a few minutes ago and we discussed this. He said it will take a while but they may as well start stocking misalignments for 1.75" mounting widths. THis is probably a good idea because alot of the pre made bracket guys build in this dimension and they are probably loosing rod end business over a 2$ misalignment spacer....
Any who, It was "OK" ed that i just grind down the 2" misalignments equally to the 1.75" mounting width since a Panhard only needs about 6* of rotation anyways....just an update
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #17 of 22 Old 04-15-2013, 05:43 PM
Technohead
Originally Posted by JohnnyZJ View Post
IRO is easy and cheaper.
its always easy to say shoulda gone claytons. but from what i see the only benefit is the Johnny Joints...... and for twice the price, not sure if that is worth it, when i can put JJs on anything anyways
Try again on the math:
IRO premium long-arm kit: $2,499.99
Clayton long-arm kit: $2,999.00
Yes, the IRO kit comes with D0uche Tech shocks but who cares . . . you need to pay an extra $250 to get real shocks.
I don't know any guys running Clayton's stuff who are wasting time retrofitting components . . .
-Eric
Technohead is offline
post #18 of 22 Old 04-24-2013, 11:34 PM Thread Starter
JohnnyZJ
I was referring to the critical path kit. Just the front long arms
Ones bolt one ones not thats the major cost diff.
Im done with off the shelf stuff: I build it myself now
07' JKUR rollin on 35s
JohnnyZJ is offline
post #19 of 22 Old 04-25-2013, 04:58 AM
speedbucket
I've got the stuff from ruffstuff....just been busy
post #20 of 22 Old 02-08-2014, 07:49 PM
speedbucket
Today I converted my track bar frame bushing to a heim joint. Having bushings on both ends gave me some steering slop and they were just to soft for my taste.
So....
1 iron rock off road double sheer adjustable track bar
7/8" heim
Drilled some plug weld holes in a properly sized Dom sleeve
Then welded it up along with the threaded bung
Done
post #21 of 22 Old 02-08-2014, 10:19 PM
newfieZJ
I'm running the Clayton's track bar . The JJ is huge . The axle end uses a clevite stock style bushing and can be had in a HD version . Twice the price , twice the product !!
I'd buy IRO short arms because good for a good price is a no brainer . Not much else . Never used the track bar , anyone who knows me on here should know my opinion on poly bushings
I'm 100% with Technohead . That don't happen too often I ran RE arms and had bushing failure issues . Bought IRO LA's and had fitment issues with no help from IRO . Ran a few JKS products with no issues , and Clayton's , well , that's just where I should have started . Comparison of their product to any other , it's obvious , they are the best . It's one of those cases where expensive ends up paying for itself .
Nice job speedbucket !!
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #22 of 22 Old 02-09-2014, 07:54 AM
Technohead
Originally Posted by newfieZJ View Post
. . . I'm 100% with Technohead . That don't happen too often . . .
-Eric
