Current draw from Body control module - JeepForum.com
post #1 of 13 Old 05-12-2008, 10:19 AM Thread Starter
purple_jeep
Hi all,
I've being having trouble with my jeep, it would die after a couple of days of not driving it. So on the weekend i took some time to discover what was wrong. After some carefull investigation i discovered that the body control module is drawing upwards of 150mA when the jeep is off...
Can anyone suggest a reason for this? Do i need to replace the BCM? Is it repairable (I am an electrical engineer).
Suggestions?
Cheers
Chris
purple_jeep is offline
post #2 of 13 Old 05-12-2008, 10:29 AM
WJChris
WJChris's Avatar
Please add your Jeep info so we can help you better. I think this will work for you.. http://www.jeepforum.com/forum/profile.php?do=extra
IOD circuit??? Normal???
http://www.wjjeeps.com/fuses.htm#DRAW
WJChris is offline
post #3 of 13 Old 05-12-2008, 10:38 AM
WJChris
WJChris's Avatar
Another thought... while measuring the current, start pulling fuses to narrow it to a specific circuit the BCM controls, unless you already have.
WJChris is offline
post #4 of 13 Old 05-12-2008, 11:46 AM
Colorado 5.9
Colorado 5.9's Avatar
Since we don't know what year you have I'll post this anyway.
http://home.sc.rr.com/janet/TSB/08-09-96.htm
http://home.sc.rr.com/janet/TSB/08-16-96.htm
http://home.sc.rr.com/janet/TSB/08-41-95.htm
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #5 of 13 Old 05-12-2008, 12:11 PM Thread Starter
purple_jeep
whoops sorry guys I have a 1998 Jeep Grand Cherokee Larado 4L
I narrowed it down to the fuse that supplies the BCM the power amplifier and the dashboard stuff.
After unplugging the supply connector to the BCM module located under the drivers dash the current dropped down nothing.
Chris
post #6 of 13 Old 05-12-2008, 12:55 PM
WJChris
WJChris's Avatar
Originally Posted by purple_jeep View Post
whoops sorry guys I have a 19998 Jeep Grand Cherokee Larado 4L
Chris
HAHAH!! That HELPS!!! 1999 or 1998??? LOL!
WJChris is offline
post #7 of 13 Old 05-12-2008, 12:57 PM
WJChris
WJChris's Avatar
from links provided and good info:
Normal ignition off draw is less than 25 milliamperes. This condition will prevent the Body Control Module from powering down which occurs approximately 30 seconds after the ignition switch is turned off. The Body Control Module draws approximately 180 milliamperes when it is in the normal operating mode.
WJChris is offline
post #8 of 13 Old 05-12-2008, 11:07 PM Thread Starter
purple_jeep
sorry about the typo, its a 1998 I have also placed it in m profile.
That memo does seem to report the same problem as what i am experiancing except the memo specifies the 1996 model of the jeep. Is this problem one that can exist on all years jeeps?
Anyone know where i can get a new/rebuilt BCM or is my only option second hand off ebay?
Cheers
Chris
post #9 of 13 Old 02-07-2011, 07:27 AM
BackBrakeBilly
I am experiencing this same exact problem!
I am going to check the BCM out today and see whats up with it...
Any advice on this will be greatly appreciated!
Thanks!
BackBrakeBilly is offline
post #10 of 13 Old 02-07-2011, 08:59 AM
tcar
Chris
96-98 GC's are identical for almost all purposes (ZJ-2).
tcar is offline
post #11 of 13 Old 02-08-2011, 04:51 PM
BackBrakeBilly
I replaced the BCM in my Jeep today and the short is still there...
I can still remove the white connector and the short goes away or as before remove the #7 fuse and the short goes away...
I need a good wiring diagram for the wires that come out of the BCM through that white connector...Anyone???
Thank you...
post #12 of 13 Old 08-14-2011, 04:33 PM
98GCLim40
Did you ever figure out what was the problem?
98GCLim40 is offline
post #13 of 13 Old 08-14-2011, 10:27 PM
JS97ZJ
It was the flip glass ajar switch..
http://www.jeepforum.com/forum/f13/b...night-1161645/
JS97ZJ is offline
Body Contorl Module or Door Control Module?? Drdan524 ZJ Grand Cherokee Forum 4 05-19-2010 01:04 PM
Current draw…Body Control Module? lucky_logger6 ZJ Grand Cherokee Forum 2 08-20-2008 12:01 PM
Bad body Control Module ? jace ZJ Grand Cherokee Forum 6 07-14-2008 06:36 PM
Driver Door Module or Body Control Module ronmaynard ZJ Grand Cherokee Forum 3 04-28-2008 08:13 AM
body control module buzzbomb ZJ Grand Cherokee Forum 8 06-30-2004 07:00 AM
