Curious?!?!?! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Curious?!?!?!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender Flares
Unread 01-25-2011, 02:55 PM   #1
dropped74
Curious?!?!?!
I have a 98 5.9 Limited that is in phenominal shape and I love it, but I would like to ge a little better mileage. Has anyone put a newer 5spd auto that the hemi uses in their older jeep. Would I get any benefit out of it and is it possible???
dropped74 is offline   Reply With Quote
Unread 01-25-2011, 03:30 PM   #2
LordHobbit
Captain Awesome
LordHobbit's Avatar
The benefits would not outweigh the amount of money it would take to fit it in and make it work. Most likely.
The only benefit I could see is that it would be less parasitic loss. I don't think the overdrive is geared much better than the 46re in your 5.9.
93 red ZJ 189k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline   Reply With Quote
Unread 01-25-2011, 03:55 PM   #3
JohnnyZJ
good lord, this forum needs a thread stickied on gas mileage, and how bad it is in ZJs.......
95' ZJ ~ trail rig
92' YJ ~ just another reason for the wife to yell at me
11' JKU ~ minvan power!
05' GMC Sierra ~ daily
JohnnyZJ is offline   Reply With Quote
Unread 01-25-2011, 07:29 PM   #4
MuddSlutt
agree
1998 ZJ 5.NINER Limited
"JEEPING... Because football, baseball, basketball, and soccer only require one ball."
[B][_]I II II II I[_][/B]
Brass Balls Offroad
[COLOR="Black"][CENTER][SIZE="4"][FONT="Showcard Gothic"][COLOR="Black"][URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #560[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
MuddSlutt is offline   Reply With Quote
Unread 01-25-2011, 11:14 PM   #5
ratmonkey
Living dead mod
ratmonkey's Avatar
It is possible to put a 545rfe in, you would need to do some custom wiring, custom mounts, shifter, and must likely a custom torque converter.
a manual trans would be a much bigger improvement in economy. I jumped 4mpg in city driving.
ratmonkey is offline   Reply With Quote
Unread 01-26-2011, 02:23 AM   #6
Goumoun
Have a set of tires with a bigger diameter. The result will be the same as a longer gear ratio.
1995 ZJ 5.2 Limited (Export)
1998 ZJ 5.9 (LX Export)
Goumoun is offline   Reply With Quote
Unread 01-26-2011, 02:34 AM   #7
ratmonkey
Living dead mod
ratmonkey's Avatar
Except for the weight penalty offsetting any gains from lower rpms.
Cruising at anything less than 1800 in an auto zj will have you below the converter stall speed and out of the power band.
Unread 01-26-2011, 03:02 AM   #8
Goumoun
Larger diameter tires, but same width, meaning also street and not AT tires. i.e.there is not a sensible weight difference between a 225/70 to a 225/75 tire height ratio IMHO.
The ZJ as most modern vehicles has a TC lock up above 50 mph, so the TC will not release at low rpm; engine to wheel transmission is 100%. Hence at cruising speed the TC will not rob power. City driving below 50 mph affects mpg quite a lot in facts.
Unread 01-26-2011, 06:40 AM   #9
ratmonkey
Living dead mod
ratmonkey's Avatar
Thanks for the lesson...but it locks at 45mph unless od is off actually.
Engine to wheel power transmission is never 100%, parasitic losses will always be present.
225/70 vs 225/75 is such a miniscule size difference it won't even register at the speedo. And 10lbs of rotating mass is equivalent to an extra 100lbs of sprung weight.
Unread 01-26-2011, 07:51 AM   #10
Goumoun
Sorry, there was no intention for a lesson, just discussing bolts and nuts issues.
