Cruise Servo Vacuum Line - JeepForum.com
post #1 of 10 Old 05-23-2013, 03:03 PM Thread Starter
smccloud
The cruise servo vacuum line on my '97 5.2L Laredo has broken and I found out the hard way that the elbows you can get from your local parts store will last around a month and then split apart as the fitting on the servo is larger than the elbows are designed for. Does anyone happen to know the factory part # for the line or just happen to have the elbow part of the line with enough vacuum line still attached that I can splice it in place that they would be willing to part with?
smccloud is offline
post #2 of 10 Old 05-23-2013, 03:17 PM
xcaliber81
Mine actually broke and I was able to use some heat shrink tubing to fix it. Do you have the old one? Shall I upload a pic of what I did?
xcaliber81 is online now
post #3 of 10 Old 05-23-2013, 03:18 PM Thread Starter
smccloud
The old one was in the back seat, but it appears that one of my nieces thought it was a toy and is no longer there
I'll look again tonight, if I can find it then I can just use some vacuum couplings to fix it. If worse comes to worse, I'll call up my dad to see if he can at least get me a part # to look up online (don't want to rely on him to get it since we aren't on the best terms right now).
smccloud is offline
post #4 of 10 Old 05-23-2013, 03:21 PM
StPaul59
Some small diamater rubber hose would work also.
StPaul59 is offline
post #5 of 10 Old 05-23-2013, 03:23 PM Thread Starter
smccloud
And the factory part # is 52078684, but it isn't available anymore and I can't find out if it supersedes via Google
smccloud is offline
post #6 of 10 Old 05-23-2013, 03:34 PM
xcaliber81
Junk yard?
post #7 of 10 Old 05-23-2013, 03:39 PM Thread Starter
smccloud
Junk yard?
Going to have to, just gotta find the closest junk yard to me first. One I normally go to is 90 miles away
smccloud is offline
post #8 of 10 Old 05-23-2013, 03:52 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I replumbed that entire line with small vacuum hose (3/16" I think) and and a plastic tee from NAPA
HighLonesome is offline
post #9 of 10 Old 05-23-2013, 05:38 PM Thread Starter
smccloud
I found the piece of the factory line where it came out of the tee, using that a elbow from O'Reilly & some electrical tape (just to make sure it doesn't come apart) it is working.
smccloud is offline
post #10 of 10 Old 05-23-2013, 11:18 PM
Oldfrog
2007 WK
I used rubber hose, not those elbows. I keep a few inches of it in my spare tire cover as a back up.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
