Cruise not working/AC not working correctly: Need Vacuum line diagram - JeepForum.com
post #1 of 4 Old 09-03-2008, 08:38 PM Thread Starter
JoshuaDHarp
After doing some research, I found that if the air conditioning is not working correctly then it could be a vacuum line, and a problem vacuum line could cause issues with the cruise control.
I am having both of these issues. There is a line by the battery that looks like it may be broken partially (it's dark can't really tell right now). Is this a vacuum line? And if so what is the best way to repair?
Anyone have a diagram?
2001 Jeep Grand Cherokee Laredo 4x4
v6
JoshuaDHarp is offline
post #2 of 4 Old 09-03-2008, 09:41 PM Thread Starter
JoshuaDHarp
Ok I decided to fix it tonight.
I found a line by the battery and it was rotted at the end, it did have a hole in it.
I cut off the end of the hose and reconnected. Cruise is now working as well as the air. The true test will be when the wife takes it on the highway with full air on. Normally it would cut out under higher RPM's. But the cruise is fixed at least.
post #3 of 4 Old 07-28-2011, 06:13 PM
Khun
josh,
hey man I'm having the same problem, do you have a picture of the line by the battery? Or a description of how the line looks? Please and thanks.
Khun is offline
post #4 of 4 Old 07-28-2011, 06:20 PM
TewSmooth18
The line he is probably talking about is like a hard plastic line that runs on the passenger side by the battery back to the firewall and has a T fitting on it..
97 Grand Cherokee 5.2 V8 - 242 swap - everything else stock atm
TewSmooth18 is offline
cruise control not working again 2tone93zj ZJ Grand Cherokee Forum 10 09-25-2015 02:26 PM
vacuum line diagram jerryconard ZJ Grand Cherokee Forum 2 10-05-2009 11:40 PM
cruise control not working evilduckz ZJ Grand Cherokee Forum 11 04-19-2009 12:59 PM
96 grand cherokee gearbox not working correctly wrangler99 ZJ Grand Cherokee Forum 1 10-11-2007 11:57 AM
AC and Cruise Control NOT WORKING xwhizx ZJ Grand Cherokee Forum 11 05-22-2007 10:07 AM
