Cruise no workie - JeepForum.com
post #1 of 12 Old 03-29-2013, 07:03 AM Thread Starter
MN59ZJ
Cruise no workie
When I press the on/off switch, the cruise light on the dash does not come on, & I can't engage cruise. The light does work, it comes on at start up. I'm not getting any error codes, and I tried swapping switches with junkyard parts, but that didn't work. the fuse is good, does this sound like a servo problem?
MN59ZJ is offline
post #2 of 12 Old 03-29-2013, 07:55 AM
zjosh93
I had a similar problem with mine. Started out that cruise would cut out randomly then stopped working altogether. Turned out to be a bad brakelight switch. The contacts for the cruise control are separate from the ones for the brake lights so your lights can work fine while the cruise thinks you are hitting the brakes all the time. Took the switch apart and found the issue, tried to fix the switch but ended up just buying a new one. Mine is a 93 so YMMV. Also I see you replaces switches but I took that as the on/off switch, if you already checked the brake switch never mind.
zjosh93 is offline
post #3 of 12 Old 03-29-2013, 07:59 AM
KoreaZJ
1994 ZJ
Verify switches and clock spring... Measure resistance between clock spring connector Pins #1 and #2 with switches in positions shown in table below...
  1. First disconnect the negative battery cable, wait a few minutes for circuits to discharge
  2. Remove steering column lower shroud cover
  3. Remove the clock spring connector (white)
  4. Check cruise switch operation with an ohmmeter between Clockspring side Pin#1 (PK) and Pin#2 (BK/LB).
KoreaZJ is offline
post #4 of 12 Old 03-29-2013, 08:03 AM Thread Starter
MN59ZJ
Thanks! Yeah, I meant the on/off switch. Would this prevent the cruise light on the instrument cluster from lighting up?
MN59ZJ is offline
post #5 of 12 Old 03-29-2013, 08:03 AM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
I have a niner like yours. Mine was a dirty contact in the switch. This is what fixed it for me:
Originally Posted by Foundrydude View Post
Spray behind all the cruise switches with electrical contact cleaner, then work the heck out of em. Repeat two or three times. Allow to dry for several hours before powering up.
If you don't think that's it, break out the multimeter and start trouble shooting
In the garage: M1 4bbl
McCloudsZJ is offline
post #6 of 12 Old 03-29-2013, 08:04 AM
KoreaZJ
1994 ZJ
PCM reads the switch, then toggles the lamp.
Not a simple ON/OFF switch. Uses resistor multiplexing where each value has a different meaning to the PCM.
KoreaZJ is offline
post #7 of 12 Old 03-29-2013, 08:06 AM Thread Starter
MN59ZJ
[*]First disconnect the negative battery cable, wait a few minutes for circuits to discharge[*]Remove steering column lower shroud cover[*]Remove the clock spring connector (white)[*]Check cruise switch operation with an ohmmeter between Clockspring side Pin#1 (PK) and Pin#2 (BK/LB).
That looks like fun.
MN59ZJ is offline
post #8 of 12 Old 03-29-2013, 09:34 AM
dnuccio
mine ended up being a broken vaccum line to the servo. replaced it and its been working ever since
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #9 of 12 Old 03-29-2013, 01:31 PM
AVR2
A broken vacuum line wouldn't show up as a problem to the PCM (it has no idea if the servo is getting vacuum or not), so you'd still get the cruise light on the dash. No cruise light means an electrical problem.
AVR2 is offline
post #10 of 12 Old 03-29-2013, 07:37 PM
dnuccio
theres no cruise light that comes on on my ZJ
EDIT: just realized he has a 98, i have a 95. probably different
R.I.P. Ratmonkey
dnuccio is offline
post #11 of 12 Old 03-29-2013, 07:39 PM
zjosh93
Yep the earlier ones don't have any light the later ones do.
zjosh93 is offline
post #12 of 12 Old 03-29-2013, 07:42 PM
dnuccio
gotcha
R.I.P. Ratmonkey
dnuccio is offline
