Cruise control not setting.. - JeepForum.com
post #1 of 12 Old 02-23-2013, 07:40 PM Thread Starter
Shane7
Just replaced the clock spring in my ZJ 2day and the cruise light comes on like it should again but it doesn't set. Whats the issue? Is it a fuse?
Shane7 is offline
post #2 of 12 Old 02-23-2013, 08:07 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
either brake switch, throttle position sensor, or vacuum leak are the most likely problems.
ratmonkey is offline
post #3 of 12 Old 02-23-2013, 08:37 PM Thread Starter
Shane7
definetly not a vacuum leak, I checked all the seals. Any other suggestrions?
Shane7 is offline
post #4 of 12 Old 02-23-2013, 09:04 PM
AVR2
As ratmonkey says, brake switch or TPS. To which I would add, faulty cruise servo or even PCM issues.
As well as checking for vacuum leaks, did you ensure that there's definitely enough vacuum at the servo? I think the minimum level is 9 mm/Hg, but you'd have to check the 1998 FSM to be sure.
AVR2 is online now
post #5 of 12 Old 02-24-2013, 04:27 AM
KoreaZJ
1994 ZJ
Reseat brake lamp switch connector.
Brake lamp switch might be out of adjustment...
  1. Push/hold brake pedal down.
  2. Pull switch plunger all the way out. (pulls hard and makes ratcheting type sound when it comes out)
  3. Release brake pedal. (should rest against the switch plunger)
  4. Pull brake pedal fully rearward firmly to reset switch position. (makes ratcheting sound when it goes in)
(Brake lamp switch has three separate circuit contacts. Just because the brake lamps work doesn't mean the cruise switch contacts are working)
Brake lamp switch might be bad. Unplug the connector, test the switch continuity between Pins #3 and #4 with meter while actuating the switch.
Cruise switches may not all be working properly. Measure resistance between clock spring connector Pins #1 and #2
Servo testing...
KoreaZJ is offline
post #6 of 12 Old 02-25-2013, 03:06 PM Thread Starter
Shane7
Servo testing...
Hm, it now makes sense to me why it would be the switch. I tried thisand still had no luck, so now it leads me to believe I need a new one all together. thanks!
Shane7 is offline
post #7 of 12 Old 02-26-2013, 03:43 PM Thread Starter
Shane7
Well I tired both resetting and replacing the brake light switch and still no luck. /: I really don't think it could be a vacuum leak but if it is, where should I look and how can I fix it?
Shane7 is offline
post #8 of 12 Old 02-26-2013, 03:50 PM
PolkaPower
Cruise control thingy is on the passenger side above the fuse box. The plastic hose from it may be broken somewhere.
(edit)I see you have the 4.0. Well here is a useless picture then.
PolkaPower is offline
post #9 of 12 Old 02-26-2013, 04:00 PM Thread Starter
Shane7
Hahah! Yeah, I forgot to mention I had the 4.0. My mistake! Thanks, anyway!
Shane7 is offline
post #10 of 12 Old 04-02-2013, 10:43 PM Thread Starter
Shane7
So, for awhile I gave up on this, but I am now kind of curious about it. Still comes on, but refuses to set. I replaced the brake switch and I'd think that if it was a vacuum leak it would throw the check engine light on, am I right?
Shane7 is offline
post #11 of 12 Old 04-02-2013, 11:02 PM
KoreaZJ
1994 ZJ
Did the resistance measurements for all the switches check out good according to the chart?
KoreaZJ is offline
post #12 of 12 Old 04-02-2013, 11:58 PM
AVR2
Most vacuum leaks won't cause a CEL.
First thing, measure the vacuum at the cruise servo and confirm that it's within spec. The magic number is in the FSM; for the 1993 ZJ the minimum acceptable vacuum at the cruise servo is 10 inches of mercury. It's probably the same for yours, but maybe not.
If that's OK, then the remaining options are (according to the troubleshooting flowchart in the FSM):
Cruise control throttle cable disconnected
Improper stop lamp and speed control switch adjustment
Faulty electrical circuit
Defective servo
Defective vacuum reservoir
AVR2 is online now
