Cruise control light replacment???? - JeepForum.com
post #1 of 6 Old 09-11-2004, 07:05 PM Thread Starter
nate438
My cruise control works fine but there is no light on the dash to tell me when it is on. Is there suposed to be one, and if so how do I go about replacing it. I'm guessing it must be burnt out? Or is there something else that would cause this to not light up?
1994 Grand Cherokee
nate438 is offline
post #2 of 6 Old 09-11-2004, 08:52 PM
Guumba
Guumba's Avatar
I could be wrong, but I don't think there is a cruise light... My '93 doesn't have one, or if it does its burnt out too heh. But I am pretty sure there is no cruise light...
1998 Jeep Grand Cherokee Limited
AKA "The Black Stallion"
120k on the clock.
Black inside and out.
5.2 Litres of gas guzzling power.
** TOTALED! UGH! **
Guumba is offline
post #3 of 6 Old 09-11-2004, 10:02 PM
Meerkat
1994 Grand Cherokee
It depends on what kind of switch you have.
When you look at your steering wheel, and you see the button to turn on the cruise, reach out and press it. Does it stay pressed in until you press it again (turn it off)? Or is it a momentary contact kind of switch that you can't tell if it is on or off just by looking at it?
If you have the kind that stays in, there is no dash lamp. If you have the momentary contact kind, then there is a lamp on your instrument console. You will have to remove the entire console (not as difficult as it sounds) to replace the bulb.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #4 of 6 Old 09-12-2004, 07:56 AM Thread Starter
nate438
My switch stays pressed in when you push it so it's sounds like from what you said there is no light. Thanks alot Guys!!!
nate438 is offline
post #5 of 6 Old 09-12-2004, 08:39 AM
kentman
kentman's Avatar
2006 XK Commander
I have had this problem for years now. My cruise light burned out. Also, one of the bulbs behind the speedometer has burned out recently. I can still see the speed, but it is not fully lighted.
Now, I just have to figure out how to get back to those bulbs. Jeep must be using cheap bulbs in the dash. I have never had dash related bulbs burn out in four to five years on any other vehicle.
Kent
kentman is offline
post #6 of 6 Old 09-12-2004, 11:17 AM
Meerkat
Kent
I don't know what year you have, but removal of the instrument cluster isn't overly difficult. You just snap off the trim pieces, remove four (I think) screws, then pull the entire cluster out. It plugs into a single socket at the bottom so there are no wires to mess with. It is quite modular. The bulbs are held in by those little "twist to lock" sockets. There are two different kinds of bulbs used, as well. The information lamps, such as cruise control, seat belts, etc all use a tiny little bulb (type 74) and the regular ones (type 194) illuminate the gauges.
HTH
Warren
Meerkat is offline
2000 WJ HVAC back light replacment jeeptorino68 ZJ Grand Cherokee Forum 7 03-31-2011 06:02 PM
Drivers running light out--- socket replacment? ZJcrawler45 ZJ Grand Cherokee Forum 0 09-18-2008 05:30 PM
Cruise Control light out ecohen321 ZJ Grand Cherokee Forum 1 07-10-2007 05:53 PM
Fix For No Cruise Control Dash Light lowdwn ZJ Grand Cherokee Forum 1 04-30-2006 03:41 PM
Cruise Control No Dash Light Fugative ZJ Grand Cherokee Forum 8 02-28-2006 03:10 PM
