cruise control doesnt work - JeepForum.com
post #1 of 7 Old 04-07-2005, 10:01 PM Thread Starter
2tone93zj
on my 93 grand 4.0L, the cruise doesnt work, i used to keep it on the "ON" position all the time and when i needed it i would just set it. now it doesnt work at all i checked the fuses whats next?
2tone93zj is offline
post #2 of 7 Old 04-07-2005, 10:18 PM
Brian's 97 ZJ
Brian's 97 ZJ's Avatar
2tone93zj,
The next thing that I would check would be the vaccume line. If the line has been disconnected or a hole has been worn in it somehow your cruise will not work. The line is connected to your intake manifold and (I'm guessing here) runs over to the passanger side of the engine compartment to a round/cone shaped thingamajig.
After that I would start to suspect the switch.
HTH
- Brian
For some reason, being a member of the
just isn't as cool... Member #1
Brian's 97 ZJ is offline
post #3 of 7 Old 04-07-2005, 10:26 PM
grandman97
grandman97's Avatar
man you've gots some balls to be offroading w/ cruise control on.. u are offroading right??
grandman97 is offline
post #4 of 7 Old 04-07-2005, 10:36 PM
Brian's 97 ZJ
Yeah, isn't the minimum cruise speed about 30 mph?
- Brian
post #5 of 7 Old 04-08-2005, 12:13 AM
grandman97
grandman97's Avatar
yea it is i have always wanted to be able to set my cruise for like 10-15mph for those really slow moving traffic jams... it sucks u cant do it under 30
post #6 of 7 Old 10-02-2009, 12:49 AM
IslandManMitch
I wish mine could be set to at 25 MPH but I have to be going at least 35 MPH.
IslandManMitch is offline
post #7 of 7 Old 10-02-2009, 01:28 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
If you only have defrost on your heater you have a vac leak(one line feeds both).
If you have overdrive torque converter lock and unlock issues you have a bad brake switch.
Most likely is that you killed the cruise control unit by leaving it on constantly. They're known to do that.
ratmonkey is offline
Cruise control, power seats, power locks, don't work. Metzroth ZJ Grand Cherokee Forum 2 01-17-2010 10:05 PM
WJ V8 cruise control doesnt work! katzonice69 ZJ Grand Cherokee Forum 13 09-14-2009 06:40 PM
4LO doesnt work? sp9861 ZJ Grand Cherokee Forum 2 03-02-2009 01:33 AM
Cruise control fails to work after undercarriage wash ArloGuthroJeep ZJ Grand Cherokee Forum 11 03-15-2006 07:05 PM
cruise control doesnt work part 2 2tone93zj ZJ Grand Cherokee Forum 6 04-15-2005 10:21 PM
