Crossmember/TC Lowering - Why? - JeepForum.com
post #1 of 29 Old 09-21-2013, 02:05 PM Thread Starter
ryanf77
I searched the Forum and Couldn't find an answer for this... I just finished installing a Rough Country 3.5" Kit on My Son's 96 ZJ. Is it necessary to install the Transfer Case Lowering Blocks? If so, Why? I am asking because it just makes Me lose some of the nice clearance I just gained!!!
Thanks in Advance...
ryanf77 is offline
post #2 of 29 Old 09-21-2013, 02:12 PM
psychoteen101
By lifting the suspension, you change the driveshaft angle. Lowering the crossmember drops the T case and helps re correct the angles. Its not a huge difference, only about an inch of drop. Ground clearance isn't a huge factor with that. Theres a reason it came with the kit, so it should be installed. If you don't, you might get driveline vibrations.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #3 of 29 Old 09-21-2013, 02:19 PM
WhiteOut
WhiteOut's Avatar
OP: You can disregard the quoted post. Next he'll tell you that you need an SYE
You don't need to install the transfercase drop. Yes, it will help the rear angle a bit, but it hurts the front angle.
WhiteOut is offline
post #4 of 29 Old 09-21-2013, 02:24 PM
Rushton623
I have a 3.5 lift and don't run the t case drop and haven't noticed a thing. You should be fine
Rushton623 is offline
post #5 of 29 Old 09-21-2013, 04:08 PM
PCsZJ
Running an IRO 3.5 lift with no transfer drop..No problems here also
PCsZJ is offline
post #6 of 29 Old 09-21-2013, 05:24 PM
PolkaPower
You don't need it. I was at 4.5 with no issues.
PolkaPower is offline
post #7 of 29 Old 09-21-2013, 05:26 PM
98GCLimited
x2
98GCLimited is offline
post #8 of 29 Old 09-21-2013, 05:29 PM
dnuccio
from what ive read on here, ZJ will never need a transfer case drop. it might need a SYE at really high lift heights (7"+), but a t case drop is a waste of money
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #9 of 29 Old 09-22-2013, 11:10 AM
LoveHate
I had vibes in the front with the tc drop, now without the drop I have no vibes. so the drop is a total waste of ground clearance.
Just Enjoying Every Puddle
Built Not Bought #693
LoveHate is offline
post #10 of 29 Old 09-22-2013, 11:31 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I had it on mine.. oh disbelieving masses.
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #11 of 29 Old 09-22-2013, 04:16 PM
Niles19
Every zj is different I had vibes w/o then I took out mine front DS and they went away. So I put in the TC drop and they are gone. who knows maybe I need to adjust my upper ca's but the TC drop doesn't bother me. just go w/o and see what happens.
Niles19 is offline
post #12 of 29 Old 09-22-2013, 06:05 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Wow, after 19 years I'm just now hearing this?
Thanks, go read the FAQs page.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #13 of 29 Old 09-23-2013, 09:38 AM
speedbucket
The Rc 3.5 kit is an incomplete lift. depending on which transmission you have you may not need it
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #14 of 29 Old 09-24-2013, 09:04 AM Thread Starter
ryanf77
So, I took the Jeep out last Night for a Cruise after the Lift and I think I answered My own Question... I have really bad vibration coming from the Rear... Guess I need to try the Drop Kit and see if that fixes it... Thanks again for all the reply's everyone... Ryan
ryanf77 is offline
post #15 of 29 Old 09-29-2013, 05:58 PM Thread Starter
ryanf77
Update: I installed the Cross-Member Lowering Kit that came with the lift kit and it helped some... But, at about 35mph the vibration starts and it's still pretty bad! It goes away for the most part when I let off the throttle... I have the Rear Drive Shaft out now and am going to install new U-Joints to see if that fixes it but I am doubtful that it will as they feel pretty tight... I'll update again once the U-Joints are in in a couple days...
ryanf77 is offline
