Create Your Own Transfer Case Linkage - Page 3 - JeepForum.com
post #31 of 73 Old 06-01-2012, 12:33 AM
94unlimited52zj
1994 ZJ
I built new linkage last year, after I put in a 231. I didn't have to lenghten my body side shift arm, I only had to reclock it to parallel the transfer case arm. A gm 231 transfercase range lever was used, one from a dodge 231 may work also. A different range lever is used to keep the same range of motion when shifting from 2hi to 4lo. The new range lever points up to the body now, instead of down as the factory one did.
94unlimited52zj is offline
post #32 of 73 Old 06-02-2012, 12:57 AM Thread Starter
harwood909
Originally Posted by MonkeyInaSuit View Post
So I've been working on the linkage and only have the cup to remove but I can't get the bolts off. I've tried using vice grips but it keeps falling off.
Is there any other way I should try and get them off. thanks for your help.
The heads on those screws are VERY short. I think they are 5/16. I used a nut driver to get them out.
Custom Machined Budget Boost
Literally Built
harwood909 is offline
post #33 of 73 Old 08-24-2012, 07:04 AM
97flexy
Do you have anymore pictures of this conversion? with a list of all parts used/ fabricated?
Check out my LCG build
http://www.wranglerforum.com/f118/my-low-budget-dd-lcg-build-142567.html#post2079244
97flexy is offline
post #34 of 73 Old 06-05-2013, 04:35 PM
UTChavok
I'm currently in the process of doing this to my ZJ. Got the old linkage completely out. Found a tab off a tcase laying in a junkyard that was next to an old 1500. I cut off the tab on the shift lever and made a new one with a longer throw. I need to figure out how much to clock that tab, weld it up and then install the shifter housing back into the jeep. I bought 7/16ths heims and all thread off mcmastercarr for the linkage. Ill post pics once I get it all done tomorrow... hopefully.
-Ronnie
UTChavok is offline
post #35 of 73 Old 06-08-2013, 08:47 PM
UTChavok
-Ronnie
UTChavok is offline
post #36 of 73 Old 06-11-2013, 11:43 AM
speedbucket
i finally found a picture of mine, there are nylon washers at the pivot points, it takes a little bit of playing around with the lengths to get the geometry correct but i ended up with at matching up with the full limits of the bezel matching the full shift of the tcase, the direct linkage is also a big advantage because you can actually feel it catching each shift position vs the factory garbage.
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #37 of 73 Old 09-03-2013, 10:58 PM
dnuccio
hate to beat a dead horse here, but just had one question. rather than redrilling a hole in the stock tcase tab, can i use the tab off a 249? its longer. and i have a 249 sitting here not doing anything so i could just grab the tab and be done with it.
maybe using a longer tab like that would allow us to not mess with the tab on the shifter?
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #38 of 73 Old 09-04-2013, 04:54 PM Thread Starter
harwood909
I tried doing that. The plat isn't at the right angle, or something. It's been a while but i have a 249 in the garage as well and i didn't use that plate.
Literally Built
post #39 of 73 Old 09-07-2013, 11:34 PM
farmerjohnson
1985 FSJ Wagoneer
Hey would you be able to send me the dwg file? I want to do this for my ZJ and the gfs XJ
farmerjohnson is offline
post #40 of 73 Old 09-08-2013, 05:11 AM Thread Starter
harwood909
its been a while and since ive got a new computer i deleted a bunch of stuff. i forgot to edit th post sorry
Literally Built
post #41 of 73 Old 09-08-2013, 09:48 AM
farmerjohnson
1985 FSJ Wagoneer
Darn alright no problem then
1985 Grand Wagoneer - The family wagon now
1996 Grand Cherokee - Parting out
1993 Cherokee - For sale
1991 Comanche - Being built as a street truck
post #42 of 73 Old 10-03-2013, 07:21 PM
dnuccio
beating a dead horse again, but can you fix the pictures? theyre not showing up for me. finally going to attempt this now that i got my front driveshaft put back together and back in. i remember now how much of a PITA the stock linkage is LOL
R.I.P. Ratmonkey
dnuccio is offline
post #43 of 73 Old 10-10-2013, 09:20 PM Thread Starter
harwood909
Pictures are back up
Literally Built
post #44 of 73 Old 06-29-2014, 01:43 PM
love2offroad
1994 ZJ
Originally Posted by blackjack12982 View Post
Is that what this is doing, eliminating that PITA body "bushing" that the linkage pops out of? I installed the Novak linkage, and it works amazing, if you're going for the same effect, then it's definitely worth it. And for a lot less cash than the Novak stuff...
What do you have to do to to use the Novak stuff in the zj? I was told it wouldn't work without modification. I might just do this cheap mod if it's just as much work
94 ZJ: 3.5" short arm lift on 32's, 231 swap w/ SYE. Miscellaneous other modifications
Some people call Jeepin' a hobby, I call it an obsession
love2offroad is offline
post #45 of 73 Old 06-29-2014, 02:39 PM
kg6mov
Hears the voices
kg6mov's Avatar
I seem to remember that the universal novak stuff isn't that hard to fit in the zj. I can't find any detailed build with it though. This is the best I can find but I think they've changed the design since then.
http://www.jeepforum.com/forum/f22/s.../#post14056556
kg6mov is offline
cheap , fix , linkage , tranfer case
Transfer case linkage problem?/242 transfer case binding in full-time setting MichiganXJ ZJ Grand Cherokee Forum 12 05-19-2015 09:47 AM
transfer case linkage orchimaxi ZJ Grand Cherokee Forum 12 04-24-2010 08:59 AM
Transfer Case Linkage RyanSBenson ZJ Grand Cherokee Forum 8 03-03-2009 01:51 PM
Transfer case linkage Doc Gary ZJ Grand Cherokee Forum 11 11-23-2007 06:19 PM
Transfer case linkage Teds98Grand ZJ Grand Cherokee Forum 5 02-14-2007 06:23 PM
