Create Your Own Transfer Case Linkage - Page 2 - JeepForum.com
post #16 of 73 Old 01-25-2012, 09:46 PM
1stblack97ZJ
very nice
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #17 of 73 Old 01-25-2012, 10:13 PM
Dyn0mitemat
Originally Posted by harwood909 View Post
This DOES keep your stock shift pattern.
The angle of the slot is the same as stock, i used the stock shift plate and just re drilled a different hole in it. No need to make your own shift plate especially if you have a spare. I can get the exact angle for you tomorrow when i'm back at school if your dead set on making your own.
The shift handle was kept at it's original angle, just lengthened to 4" and holes drilled at 3" and 3 5/8" (that is the one i used). You do need to pull the console and i will take pictures today when i get it all finished off today.
Can you elaborate a bit more on what you had to do with the actual shift level that comes through the console ?
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #18 of 73 Old 01-25-2012, 10:57 PM Thread Starter
harwood909
I hope I don't confuse you more with this little Gem hahaha
Custom Machined Budget Boost
Literally Built
harwood909 is offline
post #19 of 73 Old 01-26-2012, 11:29 AM
Dyn0mitemat
Oh ok i gotcha.
So when in 2wd it needs to point straight down?
post #20 of 73 Old 01-26-2012, 09:43 PM Thread Starter
harwood909
Oh ok i gotcha.
I can't remember exactly what angle it needs to point at but just take a marker and put an alignment dash like this
Literally Built
post #21 of 73 Old 02-14-2012, 05:10 PM
Dyn0mitemat
I was ordering some stuff on mcmaster-carr and I came across these
http://images1.mcmaster.com/Contents...g?ver=23186349
For making turnbuckles, got me thinking of this mod.
So I checked out my subscribed thread history, click it, and what do you know, I NEVER saw you updated the first page on how to do the modifications to the shifter handle itself. I just wanna thank you again, helps out a bunch. After the thread went to two pages I didn't check the first as I didn't know you updated it.
I'll be doing this here shortly, I'll let you know how it turns out.
Thanks!
post #22 of 73 Old 02-15-2012, 10:11 PM Thread Starter
harwood909
Good to hear I'm helping a couple jeepers out here
Literally Built
post #23 of 73 Old 02-21-2012, 07:35 PM
kbktulsa
1987 YJ Wrangler
i am using a cherokee shifter in my YJ I am in the process of using your ideal to make it shift better, thanks for the information
1987 jeep wrangler, 1999 LS1, 4l60E. 231j transfercase, D30 front, Ford 8.8 rear, 4 inch rc lift, tj top,tj fender flares
kbktulsa is offline
post #24 of 73 Old 02-21-2012, 10:19 PM
Dyn0mitemat
I got my parts in and haven't gotten around to it. I ordered the 1/2" thread ball joint rod ends and turnbuckle, but now that its here I think it's a bit big so I may just go back to all-thread and being creative.
I'm working on getting the 8.8 in right now, afterwards while I'm waiting on parts for the hp30 to come in I'll probably get around to doing it as I won't miss not having 4wd if I have to have the thing apart a few days because I'll have 4.56's in the rear and 3.73's in the front until I get the hp30 in
post #25 of 73 Old 02-22-2012, 09:39 AM
speedbucket
I did something similar on my wife's Dakota. I used a goodsize turnbuckle for a screendoor, eliminated the snap in studs with a shouldered bolt. Then just added jam nuts to the turn buckle
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #26 of 73 Old 04-29-2012, 10:20 AM
metallica0682
so did you use the s10 transfer case lever like the other guy? if not could you post some pics with what you had to do with the lever at the t-case I have all the parts except I either need to find a s10 lever or figure out how to use the stock one
metallica0682 is offline
post #27 of 73 Old 04-29-2012, 10:30 AM Thread Starter
harwood909
I welded up the original hole in the t-case lever and gound down and redrilled it to fit. Here are the actual dimensions of the lever....
It's a little hard to make out so just ask if you need a clearer picture
Literally Built
post #28 of 73 Old 05-31-2012, 01:40 PM
MonkeyInaSuit
Sorry I Know this is an old thread but how exactly did you get the whole linkage assembly out I'm having trouble with it thanks.
MonkeyInaSuit is offline
post #29 of 73 Old 05-31-2012, 02:11 PM Thread Starter
harwood909
Pry linkage from pivot points connecting the shifter to the case
Remove the center console from inside.
Remove the bolt holding the shift handle to the rotating lever.
Remove 4 screws holding down the "cup".
Remove the snap ring that holds the rotating lever in the cup.
Literally Built
post #30 of 73 Old 05-31-2012, 08:17 PM
MonkeyInaSuit
So I've been working on the linkage and only have the cup to remove but I can't get the bolts off. I've tried using vice grips but it keeps falling off.
Is there any other way I should try and get them off. thanks for your help.
cheap , fix , linkage , tranfer case
Transfer case linkage problem?/242 transfer case binding in full-time setting MichiganXJ ZJ Grand Cherokee Forum 12 05-19-2015 09:47 AM
transfer case linkage orchimaxi ZJ Grand Cherokee Forum 12 04-24-2010 08:59 AM
Transfer Case Linkage RyanSBenson ZJ Grand Cherokee Forum 8 03-03-2009 01:51 PM
Transfer case linkage Doc Gary ZJ Grand Cherokee Forum 11 11-23-2007 06:19 PM
Transfer case linkage Teds98Grand ZJ Grand Cherokee Forum 5 02-14-2007 06:23 PM
