Crazy vibration at hwy speed - Page 2 - JeepForum.com
post #16 of 21 Old 11-17-2010, 05:00 PM
Candymancan
Well if you want an update from me, i had the dealer change the rear diff with the mopar stuff and additive, and i also got the tires balenced. 2 were out of the balence. Vibration and noise is still there..
I recall a thread on another forums where alot of 5.9's have the same problem, so its probably some defect in these truck's. No one has figured it out yet either. in that thread anyway, however one person suspects its the NP249J transfer case. However if that were the case, then you wouldnt be having the problem with your 242, so i dunno. I suspect the noise i hear also is the pinion bearing
Candymancan is offline
post #17 of 21 Old 11-21-2010, 06:47 PM Thread Starter
Eldoradoman
My vibration problem is not with my 5.9, but my Laredo, which has the D35 and is open diff. My 5.9 has never had any vibration problem like this actually, even after swapping transfer cases and doing the lift kit.
I'm thinking I should do my rear wheel bearings for starters and go from there, just really don't have the time or energy right now, lol.
The howling immediately went away after doing the pinion bearings though, pretty cheap and easy enough fix.
1998 Bright Platinum 5.9, 242 swap, go-fast goodies ,and 3" exhaust w/Super 40, SCT Tuner, 4" hybrid lift, 33" Claw TTC Radials
Eldoradoman is offline
post #18 of 21 Old 11-21-2010, 09:25 PM
brycherokee87
2015 JK Wrangler
yeah i have the same type of problem, after going like 60 mph theres alot of vibration but it seems like its coming right inside the dash board. i was going to post a thread about it asking how to solve the problem.
brycherokee87 is offline
post #19 of 21 Old 11-22-2010, 10:14 PM
Mont
I have the same problem on mine. I did notice that the engine mounts are shot, I will be replacing them on wednesday and see if that will cure it. I think it's comming from the front drive shaft. We'll see
Mont is offline
post #20 of 21 Old 07-10-2011, 01:17 PM Thread Starter
Eldoradoman
For those of you that have this same problem, mine ended up being the transfer case output bearing, maybe start there. Thanks for all the input everyone, I ended up selling the Laredo though so I can focus on the Niner again.
post #21 of 21 Old 07-10-2011, 07:47 PM
Candymancan
Good one man, my friend whos a mechanic suspected thats what it was also when he checked out my Jeep.. I wish i replaced that bearing when i replaced my viscous coupler lol... Oh well... at least i know how to take the case apart and put it back together so it should be an easy Job. The bearing is only like $25 so maybe i'll do it next week. Apritiate you posting back what it was man.. since your problem is exactly what mine is then its probably my bearing also
Im hoping thats what it is
Vibration at low speed Magikal_ZJ ZJ Grand Cherokee Forum 11 01-24-2014 06:13 PM
Vibration when i let off gas at hiway speed. dickensheets ZJ Grand Cherokee Forum 10 12-16-2009 08:29 AM
Front end vibration at speed rickd. ZJ Grand Cherokee Forum 9 03-29-2006 04:16 PM
Crazy Vibration, Help! OrvisOwner ZJ Grand Cherokee Forum 11 09-24-2004 01:04 PM
Vibration at highway speed?????? jlr69s ZJ Grand Cherokee Forum 4 03-15-2003 12:22 PM
