Crankshaft position sensor replacement #2 - JeepForum.com
post #1 of 22 Old 05-26-2012, 10:46 PM Thread Starter
lennlin
Crankshaft position sensor replacement #2 *UPDATE* * SEMI-SOLVED*
Hey all,
Been lurking these forums for a few years now trouble shooting some minor problems of my 1995 Jeep Grand Cherokee Laredo 4.0L. I take good care of it and its pretty much mint condition. Has roughly 60,000 miles on it.
Right now my jeep will not start up but it turns over. Almost positive its the crankshaft position sensor AGAIN because the cranking sounds like the last time the CPS failed last summer. The entire jeep just shut off suddenly as I was driving down the street last time and this time is just wouldn't start. This town over charges its automotive services; I paid over $520 just to get my CPS replaced!
This time I want to do it myself. The problem is finding the actual CPS on my vehicle. I know its attached to the outside of the tranny bellhousing but I do not know what a bellhousing looks like. If I were to actually find the CPS I'd be able to order my part ASAP and run to a parts store to grab some jacks or wrenches because I am definitely not a automotives DIY guy.
to summarize:
-I don't know where the CPS is because I don't know what the bellhousing looks like.
- i know its on the driver's side but the only part I know is the air filter so if you guys could reference to the air filter I would appreciate it lol
Edit:
After finding where the CPS is, I went to go buy some tools so I thought "eh what the hell I'll just plug in a battery charger to see if it does anything". I come back and the charger says the car battery is fully charged. I took a shot at starting it again and guess what?!? IT STARTED!! It was very weak at first and the engine was sputtering oddly but it started up and I reved it a few times to make sure it didn't die on me after. The next 4 starts (in a span of 5 minutes) was pretty solid but still sounded "odd".
I'm confused now. Should I still replace the CPS or just have faith and hope it doesn't stall out on me when im driving...?
lennlin is offline
post #2 of 22 Old 05-26-2012, 11:11 PM
AVR2
If you stand looking into the engine bay, the CKS is located just behind and to the right of the rear of the valve cover, more-or-less in line with the firewall.
It's legendarily a PITA to reach, unless you've had experience changing it. Here's the location diagram from the service manual:
AVR2 is offline
post #3 of 22 Old 05-26-2012, 11:58 PM Thread Starter
lennlin
HI AVR2,
I have the Haynes manual but the diagrams confuse me when trying to match what structure what is. I wish I knew what your post was telling me but I dont even know what valve cover and firewall is. ..
Some older posts say that the connector (pigtail part) is actually closer to the passenger side and loops under the engine and finally to the bellhousing?
lennlin is offline
post #4 of 22 Old 05-27-2012, 12:17 AM
phitmein
phitmein's Avatar
the valve cover is what you pour oil into when you add oil.
The firewall is the metal wall that seperates the engine compartment from the interiors compartment.
Your CPS is behind the very rear of your motor mounted almost on the top of your transmissions bell housing .
phitmein is online now
post #5 of 22 Old 05-27-2012, 12:36 AM
KoreaZJ
1994 ZJ
Pigtail on my '94 goes over the top to the passengers side.
If your crankshaft position sensor has failed, then it usually throws a fault code.
Check HERE how to check codes.
Nearly impossible to replace the sensor while on the ground, need to be on a lift or ramps.
Goes something like this...
KoreaZJ is offline
post #6 of 22 Old 05-27-2012, 12:42 AM
hdrocknroll
More often, If your crankshaft position sensor has failed, it will not throw a fault code.
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #7 of 22 Old 05-27-2012, 12:42 AM
AVR2
Originally Posted by lennlin View Post
HI AVR2,
It may do. Connector positions can change between model years, or even between vehicles from the same model year. Mine is definitely on the air filter side of the engine.
I've arrowed the general position of the sensor in this image. It's actually deep down inside the bay. The head of the bolt is facing towards the rear of the ZJ, so you pretty much have to get underneath to replace it.
AVR2 is offline
post #8 of 22 Old 05-27-2012, 12:52 AM Thread Starter
lennlin
http://www.youtube.com/watch?v=JoWgHeARguc
Did the ON-OFF key thing and I only get codes 12 and 55 which basically was when I disconnected the battery when trying to fix my jeep.
I've heard of people doing it without a ramp or lifts but it was a b!tc# to do so I am thinking I will go ahead and buy some jacks and stands!
I'll try to get some pics and videos to further depict what I am having trouble with
lennlin is offline
post #9 of 22 Old 05-27-2012, 12:56 AM
hdrocknroll
Wire comes out on pas side by the dip stick on my 95
post #10 of 22 Old 05-27-2012, 01:16 AM Thread Starter
lennlin
Hdrock, I'm beginning to think I found the connector finally but when I try to follow the wire, it splits into 3 wires and none of them lead to the other side of the engine.
please forgive the blue arrow. The red arrow is supposed to show how I imagine the wire is supposed to route
And after a literal full day of researching and troubleshooting, I need some rest. Be back in a few hours
lennlin is offline
post #11 of 22 Old 05-27-2012, 01:38 AM
phitmein
phitmein's Avatar
in your pic., if you drew a line almost straight down from the pivoting point on your pass. front windshield wiper you would be looking more in the right area .
post #12 of 22 Old 05-27-2012, 11:29 AM Thread Starter
lennlin
Starting to get more of an idea of where it is. I originally thought the pigtail connector was supposed to be by the windshield washer fluid and the sensor would be found out by the headlights. How wrong was I!!
Now here is where I'm looking but still attempting to find it.
-Red is the motor/transmission
-Blue is where the pigtail harness of the CPS is found. Kinda close to the fuel filter
-Purple is the firewall, which is how far "deep" the sensor should be
-Yellow is the valve cover
-Green is the location of the sensor
There was another post that said it was attached to the fuel rail or remotely close? Is the fuel rail connected to the bellhousing? That is another of the few parts that I know
lennlin is offline
post #13 of 22 Old 05-27-2012, 01:05 PM Thread Starter
lennlin
Here are videos and pictures that will help you guys help me!
This is a link to a video showing my problem and what my jeep sounds like when I crank it:
http://tinypic.com/r/2qu8bgp/6
I think I found her:
I had to get in from the driver side door and wiggle into the middle of the jeep basically with my feet pointing at the front bumper
I think this is the connector to the CPS:
Another view:
ANother view, its right by the dipstick and filter like others have said:
Last view I swear
Hopefully these pictures can illustrate what direction I'm heading in! THank you
lennlin is offline
post #14 of 22 Old 05-27-2012, 01:50 PM
Oldfrog
2007 WK
Before you replace the CPS. Try wiggling the plugs ( connectors) on the PCM ( computer), firewall, passenger side. Then try to start it. If it starts, it's the PCM, another common problem. $249 at Orielly's.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #15 of 22 Old 05-27-2012, 04:28 PM Thread Starter
lennlin
lennlin is offline
crankshaft position sensor and a camshaft position sensor ? 1998jeep727 ZJ Grand Cherokee Forum 5 06-02-2011 08:29 PM
Crankshaft position sensor joeprntwj ZJ Grand Cherokee Forum 11 06-15-2010 11:44 PM
crankshaft position sensor replacement? leechris ZJ Grand Cherokee Forum 25 05-24-2009 10:55 AM
Crankshaft Position Sensor Replacement Tips IdahoZJGuy ZJ Grand Cherokee Forum 18 05-15-2009 01:13 PM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
