Crankshaft Position Sensor: - JeepForum.com
post #1 of 34 Old 03-15-2011, 11:58 AM Thread Starter
PCsZJ
I am getting confused
I just bought a new crankshaft position sensor and it did not come with a paper spacer. My Haynes manual and what I have found on here says there should be a paper spacer. My question is, are they still using these paper spacers and what if anything can I use as a replacement? I do not really want to drive back to the parts store, its 48 miles away. I have a 96, 4.0 with an autotrans and the one bolt crankshaft position senor. Thanks
PCsZJ is offline
post #2 of 34 Old 03-15-2011, 12:40 PM
TIMWCC1
Just replaced mine on a 94 ZJ and it did not have the spacer either. It worked fine.
TIMWCC1 is offline
post #3 of 34 Old 03-17-2011, 02:15 PM Thread Starter
PCsZJ
Well I just replaced my crankshaft position sensor without the paper spacer and it started up fine.
I cleared the codes and restarted it and the check engine light did not come on.
I am going to take it for a test drive and see how it goes.
I hope this solves my problems.
PCsZJ is offline
post #4 of 34 Old 03-17-2011, 02:45 PM
ajmorell
ajmorell's Avatar
The paper spacer (or felt in some cases) is just there to protect the end of the sensor. The flywheel will pull it off when you start it anyways.
ajmorell is offline
post #5 of 34 Old 03-17-2011, 02:52 PM Thread Starter
PCsZJ
I thought they used it as a gauge, so there would be clearance between the flywheel and the sensor. So that the sensor would not rub the fly wheel?
Oh well..just as long as it does what it is suppose to do and run..I am happy
PCsZJ is offline
post #6 of 34 Old 03-17-2011, 03:06 PM
JS97ZJ
That is exactly what the spacer is there for. Your lucky that the sensor didn't hit the flywheel or you'd be walking 46 miles.
JS97ZJ is offline
post #7 of 34 Old 03-17-2011, 03:20 PM
Glasssplinter
1994 ZJ
Curious about this as well, I didn't use a spacer either and haven't had any problems. Maybe the newer models are different but mine had one bolt and didn't have any movement once I put it into the hole. Where's the room for adjustment?
Glasssplinter is offline
post #8 of 34 Old 03-17-2011, 03:38 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Old mechanic trick. Just glue on a circle cut from a cereal box, it will work.
coralman is offline
post #9 of 34 Old 03-18-2011, 07:02 AM
scottfelsen
This is true. It is what I did after loosing the spacer from the steelership. A round piece of cardboard they sell for 5 dollars. lol The cereal box is the same thickness.
scottfelsen is offline
post #10 of 34 Old 05-11-2012, 05:28 PM
97CherokeeSport
Can I use super glue, wood glue, hot glue, rubber cement, contact cement? what sort of glue, I have a manual AX15 trans as well. Any help would be nice, going to put the sensor in tomorrow.
Thanks in advance!
Cole
97CherokeeSport is offline
post #11 of 34 Old 05-12-2012, 03:50 AM
AVR2
I've ordered a new Mopar CKS as a standby. If it doesn't have a spacer, I guess I'll be trying the cereal box trick. So the spacer is supposed to touch the flywheel, and then get pulled off during normal operation, leaving the end of the sensor at the correct distance from the flywheel?
AVR2 is offline
post #12 of 34 Old 05-12-2012, 06:51 AM
dusterdude
I dont understand this spacer stuff,if the sensor has a bracket made to it with a bolt hole in it,when you bolt it down it automatcally spaces
dusterdude is offline
post #13 of 34 Old 05-12-2012, 09:11 AM
Uniblurb
Uniblurb's Avatar
^ agree. The Mopar CKP didn't come with a spacer, don't remember anything in the FSM about using a spacer when installing, and I've never seen users complaining about the CKP being too close where the teeth of the flex plate ring may chew the end up.
Maybe the hole/new replacement CKP's are designed where if there is the least amount play in it then when you tighten the bolt it spaces itself? I for one would not want to put any type of glue on the end of the CKP and always wonder if it's interfering with the electromagnetic signal of the CKP itself.
Uniblurb is online now
post #14 of 34 Old 05-12-2012, 12:02 PM
coralman
coralman's Avatar
FWIW."Be sure paper spacer is attached to the bottom of sensor. If spacer is not present obtain spacer part number 5252229 and attach to bottom of sensor. Push sensor against drive plate and tighten bolt to 60 inch pounds." Excerpt from FSM.
coralman is offline
post #15 of 34 Old 05-12-2012, 12:54 PM
Uniblurb
Uniblurb's Avatar
Thanks for the head up. While I remember reading the crank sensor install section of the 96 4.0 FMS, couldn't remember reading that part.
In doing a search found this info/thread.
http://www.jeepforum.com/forum/f13/p...stion-1085609/
Crankshaft position sensor (CPS) Ramon2 ZJ Grand Cherokee Forum 7 10-30-2008 04:34 PM
Crankshaft Position Sensor beljames ZJ Grand Cherokee Forum 8 05-31-2007 02:39 AM
crankshaft position sensor? petey156 ZJ Grand Cherokee Forum 4 02-16-2007 08:56 AM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
Crankshaft Position Sensor(CPS) 97zjjeeper ZJ Grand Cherokee Forum 15 02-05-2006 12:20 PM
