Cranks but won't cart, please help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Cranks but won't cart, please help!
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 04-30-2013, 12:07 PM   #1
AustinMcIntosh
Cranks but won't start, please help!
I have 97 zj 4.0 that is stuck in my driveway.
The battery and starter seem fine, and it will just keep cranking but won't fire up. The other day it hesitated to start and I had to try like 5 times before it finally went. Then it happened again the next day. Now yesterday, no matter how many times i try, it just won't fire up. Also, sometimes when going uphill at like 2,000 rpm's it will kinda like hesitate and almost like cut out for a split second. I'm not sure if this has anything to do with it. Also, I replaced the spark plugs last week but the hesitation problem has been occurring for two months. I'm thinking, maybe bad coil pack or fuel pump. Any ideas guys??
3.5" IRO, 32 Dunlop Mud Rovers, Cragar D-Windows
Build Thread: http://www.jeepforum.com/forum/f22/97-zj-havent-thought-name-yet-1346384/
AustinMcIntosh is offline   Reply With Quote Quick reply to this message
Unread 04-30-2013, 06:46 PM   #2
95ZJ318
It might be your fuel pump. My friend has a 97 with the 4.0L and his was doing the same thing. Mechanic told him it was his fuel pump. We changed his spark plugs, ignition coil, IAC valve, fluids. Still did it after all that. We have yet to change his pump, so I will let you know if it fixes the problem on his after we finish.
95ZJ318 is offline   Reply With Quote Quick reply to this message
Unread 04-30-2013, 07:18 PM   #3
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What is missing, fuel or a spark ? Test the fuel pressure and fuel delivery from the injectors.
Testing the CranKshaft Position Sensor (CPS) is a good idea because the CPS is the most common cause of Jeep 4.0 "It cranks but won't start up".
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 04-30-2013, 07:28 PM   #4
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Check your coil for spark.
00 4.7 Laredo...KYB gas shocks, ADDCO rear sway bar and Firestone Destination tires.
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote Quick reply to this message
Unread 04-30-2013, 07:38 PM   #5
AustinMcIntosh
How do i check the coil for spark? How do I check the fuel pump pressure? How do I check the PCV?
coil pack , fuel pump , spark , start , won't start
