#1 | ||
Crank Sensor/PCM
#2 |
What are the symptoms? From my understanding, if the PCM does not receive this signal, then the engine will not start. It is easy to ohm-out. It has a high resistance across the two wires. And yes it is mounted on the bellhousing, but small hands are required. The harness extends out however, making it easy to measure.
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#3 |
You can visually see the crank sensor by looking at the bellhousing on the drivers side. There is only about a 2” gap to peek in. The harness however is routed around to the passenger side. The connector is just behind the oil filter and just above the starter motor.
#4 |
haha... I've figured out that small hands are required wich I don't have. Anyways
the symptoms are: while not start easily by this I'm mean there will be about 5-10 min of gradual clicking from the fuel pump and auto shutdown relays. while this is happening the check egine light flashes in sync with the clicking this will gradually stop and the check engine light will stay solid for a couple sec. then I can start the jeep but its only gotten worse I'm lucky if she'll even start to click. |
#5 |
Well you definitely have an electrical problem rather than a fuel delivery situation. The PCM is opening the ground for the ASD (automatic shut down relay), for some reason. It could be one of several reasons. The crankshaft sensor, camshaft sensor, or the battery is not holding a charge. On some Jeeps, when the start-up voltage is too low, the PCM freaks out well before the battery is rendered useless.
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| 1997 5.2 crank but no start, need help with crank sensor replacement. | titan66 | ZJ & WJ Technical Forum | 6 | 01-06-2010 05:25 PM |
| 93 gc crank pos. sensor 5.2l | hippiemcgrath | ZJ & WJ Technical Forum | 1 | 08-07-2009 09:59 AM |
| Crank Sensor???? | randhi23 | ZJ & WJ Technical Forum | 1 | 08-01-2007 03:20 PM |
| Could this be Crank Sensor? | dirt machine | ZJ & WJ Technical Forum | 8 | 02-22-2007 12:54 PM |
| where is crank sensor | fozman68 | ZJ & WJ Technical Forum | 14 | 08-26-2005 01:53 PM |
The time now is 12:57 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
