Quantcast crank, no start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > crank, no start
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 07-11-2008, 06:33 PM   #1
redo5
crank, no start
I recently changed the fan motor in my 00 WJ 4.0. After that I jumped it and it started and ran fine. Well it sat for a while so the battery died again. I was in a huge hurry and had to jump it off my work van. I got the cables backwards and killed the battery. Got a new battery now it wont start. The CG light, no key(?) light, abs, and low fuel light are on now. ABS light was on right after fan swap.
I know I'm a retard for getting the cables wrong but daycare is $20 for every 5 min late. Any ideas?
redo5 is offline   Reply With Quote
Old 07-11-2008, 08:44 PM   #2
Vestjam
Vestjam's Avatar
Check your fuses in the Power Distribution Center (PDC under the hood near the battery... at least thats where the PDC is on a 98ZJ... not sure on a WJ.
Also make sure you have good contact with battery.
2008 Jeep Wrangler X (Hard Top)
Incubus Off Road 511's with BFG 285/70-17
1998 Jeep Cherokee Sport
4.0L/AW4, Yakima Roof Rack
Vestjam is offline   Reply With Quote
Old 07-12-2008, 08:04 PM   #3
redo5
problem solved! Thank you sir!
Glock Forum
