crank/cam sensor or fuel related problems - Page 7 - JeepForum.com
post #91 of 98 Old 07-04-2009, 12:05 AM Thread Starter
BLACKzj52
The crank sensor got replaced like 2 weeks ago. Didn't make a difference. Bling you ever figure out ur issues yet?
Mine still likes to sputter/bogg every now and then and occasionally backfire through the intake.
Some guys at the shop I took it to said my plenum gasket is bad. I asked how and they just said its not a matter of how but when (they specialize in jeeps and are particularly fond of 5.2 zjs and gc's in general) I might look into that on mine. Mines also running lean so we replaced both o2 sensors. Still running lean. Wtf
BLACKzj52 is offline
post #92 of 98 Old 07-04-2009, 08:27 AM
rm2001wj
rm2001wj's Avatar
It could very well be a failed plenum gasket. Usually if the gasket is bad, looking down through the throttle body you will see oil that has leaked into the intake manifold. Pinging is also common with a leaking plenum gasket. The bad gasket is cause by the fact that the intake manifold is aluminum and the plenum plate is steel and the two have different expansion rates. The best fix is to replace the steel plenum plate with an aluminum plate, and then install the new gasket. You can get an aluminum plenum plate here. http://www.hughesengines.com/Index/p...2&partid=22220
Unfortunately, replacing the plate and gasket (or even just the gasket) is somewhat labor intensive so the shop time can be expensive.
These comments from the Hughes site are informative.
Also keep in mind that when the plenum cover gasket leaks it causes oil to be drawn into the intake manifold. This causes increased oil usage, smoking, pinging and power loss. The additional oil usage will cause excessive carbon to build up on the oxygen sensor. The carbon acts as an insulator effecting the operation of the sensor which controls the power, mileage and emissions. We suggest you install a new pre-catalytic (front) O2 sensor when replacing the plenum cover and gasket.
rm2001wj is offline
post #93 of 98 Old 07-05-2009, 11:23 PM Thread Starter
BLACKzj52
Ahhh that would make sense (alum vs steel statement). And I was gonna replace it with the hughes plate to begin withj For some reason I do remember looking down my throttle body at some point and seeing oil, as well as smelling it. Its definitely done then. Ill check again tomorrow. I don't have any pinging and after cleaning the terminals to my ecu I got a little bit more of my power back but not all just yet. And I'm not sure but on my way back from offroading today (after cleaning the terminals) I didn't have any spit/sputter/bog at all, well see tomorrow if I still do or not. And now my engine light is gone. Sounds like plenum is the final fix and ill be good.
And shop? Hell ill do it myself. Read a write up in the past when I was bored and it looked easy just time consuming
post #94 of 98 Old 07-06-2009, 09:50 AM
rm2001wj
rm2001wj's Avatar
Thats what I would do.
rm2001wj is offline
post #95 of 98 Old 07-06-2009, 10:32 AM Thread Starter
BLACKzj52
Great minds think alike
Edit: just looked at the hughes site once again and noticed they recommend getting this when replacing the plenum
http://www.hughesengines.com/Index/p...5&partid=23039
Is this necessary or is it just them trying to sell you something else also?
If its ABSOLUTELY necessary then ill get both when I have the money
post #96 of 98 Old 07-06-2009, 01:47 PM
xJoshxx
2012 WK
id prob do both at once eliminate the possibility of it being the one you didnt replace/
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #97 of 98 Old 07-06-2009, 04:04 PM
rm2001wj
rm2001wj's Avatar
The V8 PLENUM REINFORCEMENT KIT not absolutely necessary, but the cost is modest, and the work to install it adds almost nothing to that done when putting in a new gasket. That's assuming that you do both at the same time.
rm2001wj is offline
post #98 of 98 Old 08-16-2009, 06:44 PM Thread Starter
BLACKzj52
for anybody that is using the search function or just wanted to know for future reference
my solutions were:
-fill tranny all the way
-bad spark pluG
-fuel pump
-plenum gasket
1997 5.2 crank but no start, need help with crank sensor replacement. titan66 ZJ Grand Cherokee Forum 8 01-28-2011 08:34 PM
HELP!!!(fuel related maybe) deangtp ZJ Grand Cherokee Forum 15 09-02-2009 10:13 PM
Crank Sensor???? randhi23 ZJ Grand Cherokee Forum 1 08-01-2007 03:20 PM
Could this be Crank Sensor? dirt machine ZJ Grand Cherokee Forum 8 02-22-2007 12:54 PM
where is crank sensor fozman68 ZJ Grand Cherokee Forum 14 08-26-2005 01:53 PM
