crank/cam sensor or fuel related problems - Page 6 - JeepForum.com
post #76 of 98 Old 05-20-2009, 01:54 PM
BlingBlingZJ
Originally Posted by BLACKzj52 View Post
no. but i was thinking one of teh million sites i looked at woulda had it...
friend is hooking me up. getting the crank sensor changed for $20 on saturday!!
cant beat that.
so by then ill have refilled my tranny and get the sensor changed and we'll see what happens
wow does he know what he's getting in to.
My symptoms were:
Stalling
Stuttering/bogging
Backfiring
stall when warmed up would not start until cooled down
random check engine codes
Things I replaced that made no change:
Fuel filter
cat and O2 sensor
TPS and IAC
oil change
2002 Grand Cherokee Limited-22's-HID Projector Headlights-40 Series FlowMaster-Airaid Intake-
BlingBlingZJ is offline
post #77 of 98 Old 05-20-2009, 02:11 PM Thread Starter
BLACKzj52
his buddy works at a car dealer and worked at a huge one before
was urs backfiring through the intake?
edit: and u DIDNT replace the CPS correct? and is everything fine now?
trying to make sure i read everything correct
BLACKzj52 is offline
post #78 of 98 Old 05-20-2009, 04:01 PM
nashmd454
nashmd454's Avatar
whats the status of my ecu....????
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #79 of 98 Old 05-20-2009, 04:04 PM Thread Starter
BLACKzj52
still got it. let me hold onto it until i fix this just to make sure i dont need it. if i dont then ill sennd it back ur way.
that ok with you?
post #80 of 98 Old 05-20-2009, 05:06 PM
BlingBlingZJ
I dunno im not exactly sure. No I did not replace the CPS even though I did get a code for it but since the PCM was going crazy throwing out a lot of different codes I left it alone.
post #81 of 98 Old 05-29-2009, 05:11 PM Thread Starter
BLACKzj52
^interesting
ok. fixed my tranny band and now that my tranny is full i no longer stall at lights while in gear.
after driving it today for about 10 mins, i think i just need a simple tune up..
prolly just cap, rotor, wires(??), and ill just go new plugs since im redoing everything else
question
should i go with the Accel cap and rotor (brass connections and all that jazz) or should i just go mopar?
is the Accel worth the extra money (marginal if that)?
or is mopar better fit for a zj with stock ignition?
also, do i need to do wires? and if i do wires, should i go with some 8mm wires (assuming i go with the accel cap & rotor) or just go stock
let me know guys
think iv narrowed this down
oh forgot to mention that i didnt get to take my jeep to the dealer to get the CPS fixed. still will prolly do that just to get it out of the way and save myself some trouble down the road
post #82 of 98 Old 05-29-2009, 09:45 PM
BlingBlingZJ
Doesn't Kolak recommend the Accel cap? you should replace the rotor while you are in there also. So after you adjusted the bands it doesn't stall anymore? that's weird I didn't know the tranny could cause stalls.
post #83 of 98 Old 05-29-2009, 10:31 PM
nashmd454
nashmd454's Avatar
hey John...you aren't running anything special so normal plugs and cap and rotor will be fine. Even the wires. If you were running up there in the mods then I would recommend running different...yes...you can hold on to the ecu till you figure it all out.
post #84 of 98 Old 05-29-2009, 10:33 PM
nashmd454
nashmd454's Avatar
post #85 of 98 Old 05-30-2009, 04:41 AM
_Kyle_
_Kyle_'s Avatar
I need to save up for the Kolak ignition upgrade to compliment my Mopar Performance ECU/cheap intake.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #86 of 98 Old 05-30-2009, 04:34 PM
BlingBlingZJ
well the band actually? he said he adjusted it and filled up the tranny and it doesn't stall in gear anymore.
post #87 of 98 Old 05-31-2009, 12:03 PM Thread Starter
BLACKzj52
ill check with him.
i will do rotor at the same time
and yes if the tranny fluid is low itll cause stalling
ill check with kolak then we'll see
cool.
post #88 of 98 Old 05-31-2009, 12:06 PM
craddock01
Checked your fuel pump relay for corrosion?On the prongs? I had the same problem once.
craddock01 is offline
post #89 of 98 Old 05-31-2009, 12:19 PM
Greengc4x4
You always post what you need to do in other peoples threads, lol. What you have to do has nothing to do with johns problem,
Greengc4x4 is offline
post #90 of 98 Old 05-31-2009, 12:49 PM Thread Starter
BLACKzj52
ill check that whenever i go home next, thanks for the idea
that was my thought exactly lol
1997 5.2 crank but no start, need help with crank sensor replacement. titan66 ZJ Grand Cherokee Forum 8 01-28-2011 07:34 PM
HELP!!!(fuel related maybe) deangtp ZJ Grand Cherokee Forum 15 09-02-2009 09:13 PM
Crank Sensor???? randhi23 ZJ Grand Cherokee Forum 1 08-01-2007 02:20 PM
Could this be Crank Sensor? dirt machine ZJ Grand Cherokee Forum 8 02-22-2007 11:54 AM
where is crank sensor fozman68 ZJ Grand Cherokee Forum 14 08-26-2005 12:53 PM
