crank/cam sensor or fuel related problems - Page 5 - JeepForum.com
post #61 of 98 Old 05-14-2009, 07:44 PM
ttavenieriii
1994 ZJ
ok i have the same exact problem but i hooked a pressure gauge to the fuel rail and when it has stubbling and stuff the pressure went down to around 10psi could that still be a sensor issue like the crank or camshaft doing it??
ttavenieriii is offline
post #62 of 98 Old 05-14-2009, 08:04 PM Thread Starter
BLACKzj52
that might be the fuel pump. too many factors go into this stuff i swear!
im hoping if i get my jeep driveable by this weekend, ill take it to advanced or something and have them run a fuel pressure test and have them test my battery.
even if this was my fuel pump, i dont think that would explain some of the issues im having. maybe im wrong.
BLACKzj52 is offline
post #63 of 98 Old 05-14-2009, 09:32 PM
BlingBlingZJ
I hate when these types of problems occur because you never know what is wrong and end up spending $$ on sensor after sensor that you may not even need. It suks that you haven't fixed it yet I was sure the PCM would of fixed your issues like it did with me.
2002 Grand Cherokee Limited-22's-HID Projector Headlights-40 Series FlowMaster-Airaid Intake-
BlingBlingZJ is offline
post #64 of 98 Old 05-17-2009, 02:25 PM Thread Starter
BLACKzj52
couple things.
-installed new fuel filter. gas was sorta dirty. didnt do much
-seafoamed. LOADS of smoke [YT]Gdo1AE7JbEY[/YT]
-replaced one spark plug that i forgot to do last summer when i changed them all (broke one. went and bought another replacement..forgot to put it in)
after the seafoam and spark plug it runs much better but still not 100%
iv got some of my power back now but i couldnt tell you whether it was the spark plug or seafoam that did it.. im going to go with spark plug cuz the gap was about 55 when it needs to be 35.. (all others are 35.. or were when i put them in last summer)
i took it to advanced autos where i am friendly with one of the managers who has the same zj as me (in stock form) with 260k on it.. asked him a fe things, had him look at it. he said he doesnt think its the fuel pump (no maching to test the pressure tho), and we used a scanner and didnt pull any codes
problems still:
-engine backfire when i put my foot back on the throttle after letting off (not every single time tho, but it happens often)
-stalling when in gear idling and sometimes park>drive or reverse>drive
i have a crank sensor that i bought but have no idea how the heck it ill get installed... i dont think i can do it.
input?
post #65 of 98 Old 05-17-2009, 04:44 PM
xJoshxx
2012 WK
Originally Posted by BLACKzj52 View Post
couple things.
problems still:
input?
wow guess we had the same idea while we had free time. but i used powerfoam.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #66 of 98 Old 05-17-2009, 07:57 PM
nashmd454
nashmd454's Avatar
hey John...the manual calls for gap to be at .40 and not 35 or 55. Get all new plugs and gap them to .40. It could be possible that the backfire is from your spark not igniting properly and when you put the foot on the gas it still has a residual gas in cylinder and then it sparks again. Understand what I am trying to get at....I think you are gapped wrong.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #67 of 98 Old 05-17-2009, 08:24 PM Thread Starter
BLACKzj52
seriously? i thought my haynes said .35?
7 of the 8 have been that way since probably august lol
i dont see why it would happen now
post #68 of 98 Old 05-17-2009, 08:53 PM
BlingBlingZJ
Well you are not really going to know what your problem is until you get the crankshaft sensor installed, it can either fix it or it can remain the same but your problems all point to it being the CPS.
post #69 of 98 Old 05-18-2009, 11:41 AM Thread Starter
BLACKzj52
^dang. I really have no clue how I'm gonna do that without letting a shop do it...
Think I mighta figured out the stalling problem in gear.. My tranny seemed bone dry... I thought I filled it each time I dropped the tcase or removed my rad? oh well. Ill try filling it next weekend.
post #70 of 98 Old 05-19-2009, 08:47 PM Thread Starter
BLACKzj52
bump, not everybody at once now.
i wanna hear ur ideas/thoughts
post #71 of 98 Old 05-19-2009, 09:41 PM
rm2001wj
rm2001wj's Avatar
Many ideas have been posted, but the best is the one in Post #68. Do that and then come back.
rm2001wj is offline
post #72 of 98 Old 05-19-2009, 10:16 PM
BlingBlingZJ
Did you try backing out the screws from the pcm? is the pcm that they sent you is it the same one as the one in your jeep? you can try and replace the camshaft sensor that one is not that hard. One thing you can also try is wiggling the connector to the TPS because if it is loose it will cause the jeep to stall when you are driving. When I replaced my pcm it was still stalling and I was about to scrap the jeep but when putting my intake back on I accidentally hit the tps wires with the intake and the ZJ stalled and I knew that was my problem. You wanted ideas well here ya go.
post #73 of 98 Old 05-19-2009, 11:46 PM Thread Starter
BLACKzj52
ill get around to that asap. i just have no clue how its gonna get done
i was curious if anybody else ever had these issues and it was something else. i just dont have ALL of the symptoms normally a bad CPS throws out.
no, but when i put the other pcm in i didnt bolt it down all the way so it would be faster to remove. and the pcm i got came from a 96 5.2 zj.
i was going to order a new cap and rotor and see if that does anythigng, and because in the 2.5 years iv had my jeep i have yet to replace that. figured while i was in there i might replace the cam sensor if the funds are there. funny thing is, iv been looking around everywhere and nobody has a cam sensor for zjs.. not even wholesalemopar.com..what gives?
ill try the wires but i dont think thats it at all. the other day i completely removed my TB cleaned it, the sensors, where the sensors bolt on, and the sensor socket.. still acted the same. but ill try.
bling, what were all your symptoms? i went back and read through but you didnt really list all of them. you just touched on how it wouldnt start up
post #74 of 98 Old 05-20-2009, 07:21 AM
xJoshxx
2012 WK
u ask kolak yet? for teh sensor.
2011 WK2 ORA2 sold
xJoshxx is offline
post #75 of 98 Old 05-20-2009, 01:27 PM Thread Starter
BLACKzj52
no. but i was thinking one of teh million sites i looked at woulda had it...
friend is hooking me up. getting the crank sensor changed for $20 on saturday!!
cant beat that.
so by then ill have refilled my tranny and get the sensor changed and we'll see what happens
1997 5.2 crank but no start, need help with crank sensor replacement. titan66 ZJ Grand Cherokee Forum 8 01-28-2011 07:34 PM
HELP!!!(fuel related maybe) deangtp ZJ Grand Cherokee Forum 15 09-02-2009 09:13 PM
Crank Sensor???? randhi23 ZJ Grand Cherokee Forum 1 08-01-2007 02:20 PM
Could this be Crank Sensor? dirt machine ZJ Grand Cherokee Forum 8 02-22-2007 11:54 AM
where is crank sensor fozman68 ZJ Grand Cherokee Forum 14 08-26-2005 12:53 PM
