crank/cam sensor or fuel related problems - Page 4 - JeepForum.com
post #46 of 98 Old 05-06-2009, 06:23 PM Thread Starter
BLACKzj52
i REALLY want that performance ECU.... so badly..
i cant wait to get it.. thanks for the update on ur front. im thinking ill pick up a crank sensor when i go home saturday and then return it if its not the solution
BLACKzj52 is offline
post #47 of 98 Old 05-06-2009, 06:57 PM
BlingBlingZJ
yeah the PCM makes a big difference! the exhaust sounds so deep anyways I turned on the jeep and moved the TPS sensor wiring and the jeep stalled right away so I figured the wiring at the connector was loose so I took apart the connector and tightened the connector ends and put it back together and so far so good no more stalling.
2002 Grand Cherokee Limited-22's-HID Projector Headlights-40 Series FlowMaster-Airaid Intake-
BlingBlingZJ is offline
post #48 of 98 Old 05-06-2009, 09:32 PM
nashmd454
nashmd454's Avatar
as Kolak stated to me when I had mine done was to take it easy for awhile...let the computer adjust itself under NORMAL throttle and driving. He said I know it will be hard to resist temptation but you have to allow for the reconfiguration. I think it is like drive for a tank full and then all bets are off. I do hoope you find your bug....many people on here have the same problem lately it seems.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #49 of 98 Old 05-10-2009, 01:49 PM Thread Starter
BLACKzj52
ok tried nash's computer and that wasnt it..maybe i should disco the battery then try it again..lol
if thats the case, i still cant find that dam crank sensor! i bought one at advanced on my way back from school
post #50 of 98 Old 05-10-2009, 02:34 PM
nashmd454
nashmd454's Avatar
your supposed to disconnect the battery when working on the ecu. By the way...glad you got it...sorry it didn't cure your problem. What are your intentions now?
post #51 of 98 Old 05-10-2009, 07:37 PM Thread Starter
BLACKzj52
disco'd the battery then tried driving. at first it felt better but then the same stuff started to happen a little bit. not as bad as before but it wasnt normal..
iv got a new crank sensor now, i just need to find where it is and ill install it and see if thats it
post #52 of 98 Old 05-10-2009, 09:43 PM Thread Starter
BLACKzj52
found the sensor... really not sure how the hell i am supposed to get that out..
iv got big hands and crap.. great
post #53 of 98 Old 05-10-2009, 10:35 PM
Virmagicus
Virmagicus's Avatar
May the force be with you.
Jeff
Virmagicus is offline
post #54 of 98 Old 05-10-2009, 10:42 PM
nashmd454
nashmd454's Avatar
I wish I could help you on this....far short of looking at a fsm (do you have one?) I dunno. I do have a fsm...just never read it or even looked at it. I'd be willing to send it to you.
post #55 of 98 Old 05-10-2009, 10:48 PM
nashmd454
nashmd454's Avatar
have you tried here?? http://www.10w40.com/home/auto_repair_manuals.asp
post #56 of 98 Old 05-10-2009, 11:34 PM Thread Starter
BLACKzj52
thats reassuring.
ALSO f-in tcase.. put new snap rings in.. seal still gets chewed up.. wttttff
iv got the FSM.. cant remember if it goes in depth aobut how to remove it.. i think it just says unbolt lol. ill go back and check again tho
post #57 of 98 Old 05-10-2009, 11:35 PM
xJoshxx
2012 WK
thats reassuring.
new xfer case then just get rid of this one.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #58 of 98 Old 05-11-2009, 08:33 AM
_Kyle_
_Kyle_'s Avatar
Yea really, you couldda bought a NEW 242 by now, lol.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #59 of 98 Old 05-13-2009, 02:59 AM Thread Starter
BLACKzj52
thats not even funny lol
post #60 of 98 Old 05-14-2009, 08:14 PM Thread Starter
BLACKzj52
i was thinking today, and i just remembered that i have some kind of build up on a fuel line i believe going from the gas tank/pump to the fuel pump maybe.. cant remember exactly off the top of my head. ill take pics this weekend. i plan on changing my fuel filter (most likely needs it anyways, and thought maybe it might help)
could this cause these issues?
also other things i thought of/read about that:
-upstream o2 sensor..doesnt that effect the torque curve and a/f ratio more so than the other?
-is it possible that a crank or cam sensor could go bad without throwing a light/code?
1997 5.2 crank but no start, need help with crank sensor replacement. titan66 ZJ Grand Cherokee Forum 8 01-28-2011 08:34 PM
HELP!!!(fuel related maybe) deangtp ZJ Grand Cherokee Forum 15 09-02-2009 10:13 PM
Crank Sensor???? randhi23 ZJ Grand Cherokee Forum 1 08-01-2007 03:20 PM
Could this be Crank Sensor? dirt machine ZJ Grand Cherokee Forum 8 02-22-2007 12:54 PM
where is crank sensor fozman68 ZJ Grand Cherokee Forum 14 08-26-2005 01:53 PM
