crank/cam sensor or fuel related problems - Page 2 - JeepForum.com
post #16 of 98 Old 05-02-2009, 05:42 PM Thread Starter
BLACKzj52
Originally Posted by nashmd454 View Post
hey John, off topic....if you choose the route of flashing your ecu (pcm is part of the ecu...so the same....ok) you will need to send Kolak yours...which means now you have to get one to just to drive like I did. If that is the case...holler at me and I will loan you mine that I have laying around....k?
awesome thanks. i cant even drive my jeep right now.. lol
edit: nash can i just buy urs off you? i just want to be able to drive right now
BLACKzj52 is offline
post #17 of 98 Old 05-02-2009, 05:43 PM Thread Starter
BLACKzj52
Originally Posted by BlingBlingZJ View Post
looks like the security system is disabling it somehow. Did you disable the alarm?
no i did not.
im not sure exactly how that happened...
this is so confusing
post #18 of 98 Old 05-02-2009, 06:12 PM
BlingBlingZJ
did you try backing out the two screws in the middle of the PCM? they are known to short out the pcm because they are too long.
2002 Grand Cherokee Limited-22's-HID Projector Headlights-40 Series FlowMaster-Airaid Intake-
BlingBlingZJ is offline
post #19 of 98 Old 05-02-2009, 06:32 PM Thread Starter
BLACKzj52
i was unaware of that. i dont time to try that right now. maybe sunday night or monday monrning before i go back to school.
ill report back
post #20 of 98 Old 05-02-2009, 09:04 PM
nashmd454
nashmd454's Avatar
just send me your address again and I will send it to ya. Jedi Master takes care of young Padawan....hmmhmhmhmhm
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #21 of 98 Old 05-02-2009, 09:15 PM
rooster51
Dude, after watchin your vid, Im seriouly bettin CPS.
rooster51 is offline
post #22 of 98 Old 05-02-2009, 10:09 PM
GeorgeTown
I just had my egine renuilt and then it kept stalling out a flodding and it turned out to be the cam sensor
You can try that
GeorgeTown is offline
post #23 of 98 Old 05-03-2009, 07:54 AM
baxy
yes the alarm is definatly activated
use the key in the drivers door to disarm if that doesnt work try the passenger door
let us know if you get it cancelled
charge the battery sounds a little low
baxy is offline
post #24 of 98 Old 05-03-2009, 01:53 PM Thread Starter
BLACKzj52
we'll see. i think its either that or the ECU.
im gonna have nash send me his old ecu and we'll see if it makes a difference. if it doesnt then ill send it back to him and ill go buy a cps
You can try that
i was thinking that, but the more i searched the more i kept hearing symptoms such as stalling while cruising at a constant speed. mine hasnt done that at all. it stalls when stopped at a light.
i just realized that. the reason why i did not suspect that at first is because i forgot i had my horn removed (for installing a new rad and reinstalling my kor radiator support) so i couldnt hear it going off lol.
and yeah my battery was low cuz i was playing music all day on it while working on it. once i jump it and drive it around/let it idle its fine.
post #25 of 98 Old 05-03-2009, 02:46 PM
sdowney717
do you have a factory alarm?
If it is set armed it will disable the running of the engine. It will fire up and die.
The lights will flash weirdly even after the battery is disconnected.
The key interlock on the drivers door deactivates the alarm, if the switch is bad it wont disarm when you open the door with the key. But then the lights and horn should also sound.
I think you can deactivate the alarm by wiring the key wires to ground or together like the key would do when you put it in the lock.
I would be surprised if the computer had failed.
sdowney717 is offline
post #26 of 98 Old 05-03-2009, 03:03 PM Thread Starter
BLACKzj52
yeah its factory.
that is what the lights were. and most likely what wouldnt let it start.
yeah iv seen the ol' yellow purple wire trick
and from what iv heard its not all TOO uncommon for the comp to go bad.
post #27 of 98 Old 05-03-2009, 04:28 PM
BlingBlingZJ
so have you gotten it to run after you disabled the alarm? if so is it still stalling? Usually when the PCM starts to go bad it screws with all the sensors and that's why it stalls. Mine would run great if I disconnected the battery and as soon as it warmed up it would stall.
post #28 of 98 Old 05-03-2009, 04:39 PM
Some_Anchovies
That's definitely got to be something with the PCM/Crank sensor working together throwing off the timing enough to cause it to die.
Have you tried unplugging the negative cable on the battery overnight and trying it again? I believe after about 15 min. your PCM gets reset, so you really don't have to leave it unplugged overnight, but its worth a try. That will also reset any alarms or anything that is being triggered. Might run a little rough till the PCM relearns the operating conditions again.. if the engine starts normally.
Then, I'd look towards the Crank sensor that controls timing.
Some_Anchovies is offline
post #29 of 98 Old 05-03-2009, 07:58 PM Thread Starter
BLACKzj52
turned off the alarm, and it started right up no prob.
nash will be sending me a pcm here soon, an im thinking about picking up a crank sensor at advanced autos (theyr like $50). plus i know a manager there, he also drives a black 96 limited 5.2
so maybe ill be able to but it and if thats not the problem he could prolly let me return it for a full refund.
im starting to think its the CPS more than anything now.
i didnt get a chance to drive it tonight tho..
post #30 of 98 Old 05-03-2009, 08:19 PM
nashmd454
nashmd454's Avatar
it won't be long till I give you mine....geez...you ain't my son and I sure am going broke due to you...I hope College pays off...n/m you went to Ohio State and not THE U of TEXAS.
seriously the ecu will get sent out this week (probably tomorrow) so hopefully that works for you. The only problem I have is when I get my stroker motor in...I will have to have my ecu reflashed all over again.
1997 5.2 crank but no start, need help with crank sensor replacement. titan66 ZJ Grand Cherokee Forum 8 01-28-2011 07:34 PM
HELP!!!(fuel related maybe) deangtp ZJ Grand Cherokee Forum 15 09-02-2009 09:13 PM
Crank Sensor???? randhi23 ZJ Grand Cherokee Forum 1 08-01-2007 02:20 PM
Could this be Crank Sensor? dirt machine ZJ Grand Cherokee Forum 8 02-22-2007 11:54 AM
where is crank sensor fozman68 ZJ Grand Cherokee Forum 14 08-26-2005 12:53 PM
