Crank but won't start - JeepForum.com
post #1 of 4 Old 07-05-2009, 10:28 AM Thread Starter
dstockton
I have a 2000 Jeep Grand Cherokee and I haven't had any problems with it but today I pulled out of my drive way and it died and now it won't start.
It has power and cranks but doesn't start. Kind of like me fuel pump isn't working. But i don't think its that because when I turn my key on my gauges barely move.
i've been reading around on this forum and kind of thought it might be the crank sensor from what others have experienced.
Any ideas?
Thanks ahead.
dstockton is offline
post #2 of 4 Old 07-05-2009, 10:59 AM
tfgnt16
2009 WK
I just had this problem yesterday morning, except I was driving down the parkway at about 55 when it died on me. All signs lead to the CPS going bad. On your dash, do any gauges register, is your engine light and sentry key light on at all?
My jeep is sitting at a dealer 5 miles away, I might go run over there today and play with the CPS wires and harness just to see if that's the problem.
2001 WJ Laredo 4.0L - Sold!
2009 WK Limited 5.7L HEMI
tfgnt16 is offline
post #3 of 4 Old 07-05-2009, 08:44 PM Thread Starter
dstockton
I had a independant mechanic tell me today it was the pcm and only the dealership could fix it. What do you think?
post #4 of 4 Old 07-28-2009, 06:20 PM
thelazyman
I have the same issue with my 2000 grand cherokee 4.0. Ran fine yesturday and today it just cranks but doesn't start. I filled it up yesterday as well. Now my fule light is on, the gas gauge reads empty and my voltage reads 9 volts. However I know I have gas, and the engine cranks over fast so it isn't the battery. Did anyone figure out what the problem was?
thelazyman is offline
1997 5.2 crank but no start, need help with crank sensor replacement. titan66 ZJ Grand Cherokee Forum 8 01-28-2011 07:34 PM
96 Zj 4.0 Crank No Start bigbill888 ZJ Grand Cherokee Forum 5 01-15-2010 08:12 AM
4.7 crank no start 95pathy ZJ Grand Cherokee Forum 8 11-07-2009 01:15 PM
4.0 will not crank/start lakailimited06 ZJ Grand Cherokee Forum 4 11-07-2009 10:00 AM
Won't start on first crank. 7thStranger ZJ Grand Cherokee Forum 6 07-02-2004 11:39 AM
