Cragar soft 8's... ! - JeepForum.com
post #1 of 9 Old 03-04-2012, 12:20 PM Thread Starter
Myusername1674
So I'm looking into getting some new wheels, right now i have stock waffle wheels that are painted black. I've thought about getting Cragar soft 8s, as everybody gets them so they can't be bad I'd guess.
My real question though is this:
I have stock tires which are 235/75/15
I'm assumming that my new rims won't fit these tires correctly and also fit my future tires... Which will probably be 285/70R17E
Link: http://www.sears.com/shc/s/p_10153_1...6&blockType=G6
would i need 17 wide wheels?
How wide should i get?
Here's a link to summit racing cragar wheels list:
http://www.summitracing.com/search/B...keyword=Soft+8
Thanks for any help
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #2 of 9 Old 03-04-2012, 12:37 PM
JrMechanic
Why would you put E rated 17" tires on a steel rim?
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #3 of 9 Old 03-04-2012, 12:39 PM Thread Starter
Myusername1674
Honestly idk what that means, thats just around the size that I would like.
What does E rated mean?
(in progress)
post #4 of 9 Old 03-04-2012, 12:51 PM
PolkaPower
E rated is a very firm tire with a ten ply rating. http://www.tirerack.com/tires/tirete....jsp?techid=55
I have e rated tires because that's the only ply they offered in the size I wanted. They are not bad but ride like a truck. I don't worry about puncturing them very often off road.
PolkaPower is online now
post #5 of 9 Old 03-04-2012, 02:34 PM Thread Starter
Myusername1674
Gotcha, thanks!
Do you know what size wheel i need to get?
(in progress)
post #6 of 9 Old 03-04-2012, 02:37 PM
Mike97ZJ
I hate steel wheels. They're heavy and they rust eventually. For a trail only rig fine, but if you drive it much there's a performance and mileage penalty that comes along with them.
You don't need a 17" wide wheel, that 17" measurement is for the diameter. A 17" tire goes on a 17" wheel, as a 16" tire goes on a 16" wheel, and so on.
I wouldn't go over 8" wide for the wheels, in fact as long as that tire isn't more than 10.50" wide, a 7" wide wheel will work as well. That's what I run with my 31x10.50's, and it works very well.
Mike97ZJ is offline
post #7 of 9 Old 03-04-2012, 04:47 PM Thread Starter
Myusername1674
Thanks! Are there other cheap wheels that you know of that aren't steel??
(in progress)
post #8 of 9 Old 03-04-2012, 04:56 PM
LouC
2007 WK
First what do you want to accomplish? If you want to use the Jeep off road, the steel wheels are OK because they can take a beating and be replaced for much less than an alloy wheel. I am not a big fan of aftermarket wheels that are not hub centric. Many aftermarket wheels are not. Most OE wheels are hub centric, meaning that the centering hole fits perfectly on the hub. Hub centric wheels are much less suseptible to vibrations because the wheel/tire assembly runs in the proper relationship to the hub. If you want steel wheels, you can get 15x7 steel wheels that were used on Cherokees and Wranglers from Chrysler still, they are hub centric and fit perfect. And your current tires will fit fine. You can go up to a 30" tall by 9.5 in wide tire max on a stock ZJ with no lift and they will fit those rims fine. The OE steel rims will cost more but fit better and run truer. I have steel wheels for my snow tires on my 98 ZJ (OE Cherokee rims) and for my 07 WK (Steel OE rims used for spares on WKs). Yes they do weigh more, but I don't see any big problem with them at all.
LouC is online now
post #9 of 9 Old 03-05-2012, 08:33 AM Thread Starter
Myusername1674
So how can I know if its hub centric or not? I see a lot of jeeps in my area running similar wheels to these ones that I found. No zj's with them though, I've only seen one our two zjs around here that are lifted/modded.
So say I bought a 15x8 wheel? Could my stock tires fit that you think?
(the main reason I would get new wheels is for less back spacing over stock jeep wheels, I.e. 4 inches[the ones I want] instead of 5.25 inches[i think is my stock wheels bs]
Thanks! : thumbsup:
(in progress)
cragar soft 8's 67jeepstang ZJ Grand Cherokee Forum 29 12-07-2014 04:32 AM
Cragar soft 8 on a ZJ 95_ZJ_Limited ZJ Grand Cherokee Forum 2 02-03-2011 08:49 PM
Cragar Soft 8s raider650 ZJ Grand Cherokee Forum 4 10-22-2008 02:51 PM
WJ Cragar Soft 8s tsconver ZJ Grand Cherokee Forum 13 09-10-2008 12:24 PM
cragar soft 8's on 97 ZJ Mudder6699 ZJ Grand Cherokee Forum 5 03-24-2007 08:48 PM
