Crackling when engine is revved 2500-3000 rpms? - JeepForum.com
post #1 of 2 Old 03-05-2006, 11:57 PM Thread Starter
FatAlbert
When I rev my engine up to around 3000 rpms in neutral, I hear a very noticeable cracking/backfiring noise. This "crackling" occurs when the rpms have peaked and are dropping back down to idle.
What could this be? Is this normal?
It's just been bugging me for quite some time now.
Thanks.
2012 WK2 :: V6
FatAlbert is offline
post #2 of 2 Old 03-06-2006, 05:53 AM
Meerkat
It could be caused by just about anything.
Assuming the noise you describe has a combustion source, you may be hearing unburned fuel igniting as it is evacuated from the cylinders.
To help ensure your combustion system is working properly, clean the throttle body and combustion chamber, run some fuel injector cleaner through the tank, replace your O2 sensors, and do a compression test.
If the noise continues after that, check the timing to ensure your timing chain hasn't stretched too much.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
transmission shifting between 1900 RPMS and 2100 RPMs very often bigstinger ZJ Grand Cherokee Forum 12 08-30-2008 01:16 PM
A?C cycling off when engine is revved up... slowpokedotcom ZJ Grand Cherokee Forum 2 08-01-2008 08:13 AM
engine vibration at 1500 rpms?? CrazyDrivinJoe ZJ Grand Cherokee Forum 3 03-02-2008 09:10 AM
Engine RPMs fluctuate about 300rpms....is this a tranny problem? Starrman ZJ Grand Cherokee Forum 4 12-16-2006 06:04 PM
washed engine-now RPMs way too high? HELP cherokeesuv ZJ Grand Cherokee Forum 5 08-14-2005 10:54 PM
