Is cracked manifold causing rough idle? - JeepForum.com
post #1 of 5 Old 09-18-2003, 11:50 AM Thread Starter
skyguy
I recently posted a thread on a mystery vibration in my '93 ZJ with the 4.0 I-6 at low idle. The only thing I can find that might be a problem is the cracked exhaust manifold. My question is:
CAN THIS CAUSE THE I-6 TO RUN ROUGHLY BY MESSING UP THE READING TO THE OXYGEN SENSOR?
The vibration becomes tolerable if I take it out of drive and put it in neutral and turn off the AC, thus effectively raising the rpm's by a few and allowing the engine to run a bit smoother. It seems like the rpm's increase and decrease slightly every few seconds while idling also. Could this be the computer picking up conflicting info from the O2 sensor and other EFI sensors?
Thanks for any suggestions.
skyguy is offline
post #2 of 5 Old 09-18-2003, 04:17 PM
Big Dumb White Guy
Big Dumb White Guy's Avatar
here's what happened to me...
mine ran like crap - cracked manifold - it causes the O2 sensor to "see" more O2, then pours the gas in. you end up with a folded out spark plug. that's what the bad idle is from. just fixed it all. ebay has a stainless steel exhaust manifold for $150 (or so). you could go with header(s), if you have the cash..... check the plugs...
let me know how it turns out for you.
good luck!
repost Nazi's suck!
A guy walks into the psychiatrist office wearing only Glad Wrap shorts. The shrink says, "Well, I can clearly see you're nuts."
Big Dumb White Guy is offline
post #3 of 5 Old 09-18-2003, 07:09 PM
RockPaws
RockPaws's Avatar
If the exhaust manifold is cracked, get it fixed very soon. Its also a safety concern. An exhaust leak in the engine compartment can get into the cabin from the fresh air intake below the windshield. And you can't smell carbon monxide...bad to breath.
If the manifold is cracked bad enough, it will cause a rough idle. I would also check the ignition system for problems.
When you have your manifold replaced, use either a new one from the Jeep dealer or install a Banks or Borla header. The aftermarket "Cheep" manifold are just that ....Cheep. I have installed a number of them, They usuall come back .. cracked.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #4 of 5 Old 09-18-2003, 08:45 PM
demtjcj
i am having the same problem. what ignition parts do you think you should check. thanks
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline
post #5 of 5 Old 09-19-2003, 04:29 PM
demtjcj
can naybody help with this. or have a suggestion
demtjcj is offline
Cracked manifold? jutgin WK Grand Cherokee & XK Commander Forum 5 10-31-2009 07:26 PM
Battery gauge and rpm's drop at idle, causing overheating im90gsx ZJ Grand Cherokee Forum 5 07-05-2009 04:28 PM
Cracked Manifold mjs691 ZJ Grand Cherokee Forum 4 03-17-2009 03:46 AM
Cracked Exhaust Manifold hellrazor ZJ Grand Cherokee Forum 20 02-14-2006 09:37 AM
cracked exhaust manifold KOPY KAT ZJ Grand Cherokee Forum 1 01-22-2006 04:13 PM
