#1 | |
courtesy lights problem
i'm having a problem with the courtesy lights, i pulled out the relay to keep them off if i put the relay back they stay on all the time, i can,t install the monitoring part of my prestige alarm because they dont work.
It is anything that can be fixed or should i replace the BCM. thanks.
#2 |
Original GC'er
Is the slider switch all the way over? What year jeep do you have?
1993 Jeep Grand Cherokee Limited 4.0L I6 - OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap - 1970 Jeepster Commando 225 V6 32"x11.5" BFG A/T 4" Lift 1987 Suzuki LT230S Quadsport 1996 Artic Cat ZR580 EFI 2005 Honda TRX450R "For every one thing I fix two things break" |
#3 |
is a zj 1997 grand cherokee laredo, and the lights does not turn on even i move the slide from top to bottom or viceversa
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
