A couple quick questions. - JeepForum.com
post #1 of 11 Old 06-30-2009, 07:38 PM Thread Starter
G-Wagon00
this might all be dumb and all bui need to know the answers to my direct questions ASAP. ok here we go:
1. My jeep is overheating, but only when the A/C is on and being ran for a while. Whats the problem
2. How do i know what springs are Upcountry and which ones arent?
3. Whats the best way to get a little bit more power out of my jeep? i just put 32s on it and its not struggleing but it could use a pick me up.
4. I went to get my jeep alignment and its pulling to the right. they said i need to get the tires counter balenced, would that cause them to pull to the right?
I really hope yall can help me. Thanks a bunch
Looking for 04 Limited Grille, Tow Hooks for WJ(Rustys or OEM),.
nightcrew # 81
G-Wagon00 is offline
post #2 of 11 Old 06-30-2009, 07:41 PM
gatorayde
Not sure on the other two, but you definately need gears for #3. And you have 31's (245/75/16 by your profile) not 32's
gatorayde is offline
post #3 of 11 Old 06-30-2009, 10:12 PM Thread Starter
G-Wagon00
anyone else? i do have 32s just put them on yesterday. havent changed the profile yet
nightcrew # 81
post #4 of 11 Old 06-30-2009, 10:16 PM
gatorayde
Gotcha, well then definately gears.
post #5 of 11 Old 06-30-2009, 10:19 PM Thread Starter
G-Wagon00
what gears would you run?
nightcrew # 81
post #6 of 11 Old 06-30-2009, 10:34 PM
gatorayde
4.10's or 4.56's. If you're dead set on sticking with 32's forever and want a lower RPM at highway speeds, then get 4.10's. Otherwise 4.56's are the way to go.
post #7 of 11 Old 07-19-2009, 12:24 PM Thread Starter
G-Wagon00
so 4.10s are the way to go? is that everybodys view or should i go with the 4.56s?
nightcrew # 81
post #8 of 11 Old 07-19-2009, 12:26 PM
blutegra1992
On a different note.. if you are looking for a the UC package.. I have a set of UC springs and UC shocks for the WJ I am not using anymore that are forsale!!
To find out if you already have them or not, request a buildsheet from Jeep. Its fairly obvious though just by looking at a stock GC, the UC looks great compared to the regular springs.
blutegra1992 is offline
post #9 of 11 Old 07-19-2009, 12:43 PM Thread Starter
G-Wagon00
how much would you want for those springs?
nightcrew # 81
post #10 of 11 Old 07-20-2009, 02:00 AM
sandman
1: start with a radiator flush and see if that helps
2: UC springs are longer and came with red shocks on the ZJ, not sure about the WJ
3: gears, tune up, super charger,
4: not sure what they are talking about, what did they say the problem was?
1993 Jeep ZJ. 4.0
sandman is offline
post #11 of 11 Old 07-20-2009, 02:19 AM
Minivan
Something cheap to do for some added ponies would be to bore the throttle body, I just did mine this weekend and it actually makes a difference. It won't make your jeep pull wheelies, but it helps.
Also, you can modify the stock air box for better flow by cutting the tube inside the lower box. Also not a huge difference, but it helps.
Put an exhaust pipe from a V8 WJ, since it is bigger and flows better. Or just an after market cat back.
Move the IAT sensor to the filter box, computer thinks the incoming air is cooler.
If you got the coin to regear, this will make the biggest difference. I'd go 4.10 myself, but I drive on the freeways more than I'd like.
For your cooling problem, check to make sure the electric fan is turning on. Also make sure there is no mud/leaves between the rad and condensor.
Tire balance will not make your jeep pull one way or the other. You were not clear on if it was before or after your alignment, but if it's after, the tech probably compensated a little too much for road crown. Just take it back.
No clue about the UC springs.
It's always darkest before dawn... so if your going to steal your neighbors newspaper, that is the time to do so.
Minivan is offline
quick couple of questions th3godf4th3r ZJ Grand Cherokee Forum 6 05-10-2008 12:41 PM
Couple quick questions S_L_W ZJ Grand Cherokee Forum 2 10-21-2007 01:58 AM
A couple quick questions... JeepHunter89 ZJ Grand Cherokee Forum 4 09-07-2007 01:52 PM
Couple quick questions. hinchcliffe ZJ Grand Cherokee Forum 3 10-20-2006 10:30 AM
Couple quick questions... AppleJax ZJ Grand Cherokee Forum 6 10-18-2005 02:09 PM
