Couple of questions - JeepForum.com
post #1 of 3 Old 02-11-2013, 12:28 PM Thread Starter
matholland
Couple of questions
Alright guys...couple of things on my list...
First, my AC compressor has been squeeling ever since I got the jeep....only happens when the compressor kicks on...has new belt, has new idler pulley...I know its the compressor...I have never replaced the bearings/clutch in a compressor...from my understanding...you do not have to drain the coolant and refill it correct?
Second...my power steering pump is leaking at the bottom where it connects to the tie rod or whatever...Do I need to replace the whole power steering pump, or is there just a seal there you can replace?
3rd...there is something in my jeep draining my battery and not sure what it is...how can I go about figuring this out??
4th...Rear main is leaking a bit...how bad of a pain is it to replace?
5th...Rear wiper does not work...replaced motor and still doesn't work...it will spray windshied wiper fluid...electrical i guess??
6th...I would like to wire a switch inside of my jeep to control my winch...have saw it done, just don't know how to do it.
7th...Most of the time when it starts...especially cold, it kind of struggles to start...but I know when it is warm, my remote start will not start it...it turns over, but it thinks it starts and does not...it has new plugs, new wires, cap, and rotor...not sure what else it would be?
matholland is offline
post #2 of 3 Old 02-11-2013, 01:24 PM
Mark05059
[QUOTE=matholland;14948440]Alright guys...couple of things on my list...
You do not have to drain and refill it. You may need to have it serviced and have oil added to the system.
This would be the steering box and not the pump. Yes there are seals available to fix the leak. As a temporary fix you can try putting one capful of brake fluid into the ps pump.
[QUOTE]
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 3 Old 02-11-2013, 01:31 PM Thread Starter
matholland
Do you have to have any special tools to change out the bearings and the clutch? Also the steering box seal, what is that seal called? I have tried lucas power steering leak already with no avail.
