Could my 5.9 pull a trailer with another Jeep/Camaro on it ? - Page 2 - JeepForum.com
post #16 of 47 Old 08-11-2013, 07:55 AM
leadfootny
For that kind of trip, I would certainly get that rear end noise checked. Sounds like you have a bad wheel bearing if the noise changes as the sides are loaded/unloaded. Super easy to change and takes about a hour. I don't know what a camaro weighs, but I have looked into using the niner s a tow vehicle for my lifted zj. General consensus is that the 5.9 can do it assuming you have outfitted the 5.9 properly. This means change the diff fluid to 85-140w synthetic, trans cooler, air bags/helper springs and upgraded brakes. I personally have towed a saturn on a tow dolly with a zj (my 4.0 before it was lifted) about 400 miles where at one point I did need to make an emergency stop from 65 mph and was interesting. I had to really stand on the pedal and hold on the steering wheel to keep it under control. Don't know what the dolly weighs but the car was about 2500...jeep was loaded with tools as well. Your results will vary with uhauls reps on how much trouble they will give you with renting. The individual I was dealing with almost didn't let me take the dolly because she couldn't read the tow hitch rating on the hitch itself (had to get a little upset with her to move things along), but I've rented other trailers from them where they practically just gave me paperwork and pointed one out and said 'there ya go'.
96 ZJ 4.0
98 ZJ 5.9
leadfootny is offline
post #17 of 47 Old 08-11-2013, 08:13 AM
LouC
2007 WK
Honestly I woud not. It's going to weigh in at well over 6000 lbs and you have ZJ brakes and the soft rear suspension. You would need to be safe a WD hitch/electric brakes. If its a Uhaul the come with surge brakes and they do not have as good control.
I have towed 4000 with a ZJ (good trailer brakes) well balanced trailer Bilstein shock, air bags and oversize LT rated tires . 2000 over that, I don't know if it's safe, I would do it with my WK because it's rated for 7200 and has much better brakes.
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #18 of 47 Old 08-11-2013, 10:48 AM
SchizophrenicMC
2016 JK Wrangler
Towing a 2200lb trailer with a 4000lb Zeta on top of it? No. You can't do that with a ZJ. Especially since your ZJ doesn't have a brake controller, and it has a noise in the rear end.
Signature rules are dumb
SchizophrenicMC is offline
post #19 of 47 Old 08-11-2013, 01:37 PM
dnuccio
Originally Posted by stubburnjdh View Post
Why not rent a tow dolly? Much lighter than a trailer.
Camaro is rear wheel drive, he'd have to pull the driveshaft
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #20 of 47 Old 08-11-2013, 01:47 PM
dnuccio
uhaul trailers dont need a brake controller.
again, i towed a 3800lb car on the car trailer from them (6k total) and it stopped fine with the surge brakes.
you can tow anything with anything (provided the vehicle is properly equipped) you just need to know how to drive with that load back there.
i would however be worried about his rear end noise
R.I.P. Ratmonkey
dnuccio is offline
post #21 of 47 Old 08-11-2013, 02:50 PM
SchizophrenicMC
2016 JK Wrangler
I'm under the impression he also plans to load down the ZJ with various things they'll be moving, and even at 6200lbs, he's over his tow capacity by more than 1000lbs, and even that is rated with an empty vehicle.
I would not tow that load with that tow vehicle. Not safe for the driver, the cargo, or the vehicle.
post #22 of 47 Old 08-11-2013, 03:01 PM
kachink
This. I tried to rent a trailer to move an MGB with my XJ (factory to package) and no one wanted to rent it for anything smaller than a full size pickup. I ended up with a tow dolly and it was a piece of cake. Just make sure you follow the instructions in the owners manual about how to set the transfer case, etc. on the towed vehicle.
kachink is offline
post #23 of 47 Old 08-11-2013, 03:17 PM
jeeepguy
jeeepguy's Avatar
Ive done this at least 30 times. Tow dolly, pull the ds from the towed vehicle and you will be just fine. Just drive safely.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #24 of 47 Old 08-11-2013, 03:26 PM
WhiteOut
WhiteOut's Avatar
Bad idea all around. Car+trailer+stuff in Jeep will put you way over the tow limit. With that kind of weight you'd want electric brakes, a controller, WD hitch and better brakes on the Jeep. This whole thing also assumes that you have a class IV hitch
WhiteOut is offline
post #25 of 47 Old 08-11-2013, 03:59 PM
jeeepguy
jeeepguy's Avatar
ZJ from the factory is rated to tow 5,000lbs (class 3) and with a rig in generally well maintained condition, this tow is easy to do.
Again, with a tow dolly, the Camaro dry weight and 500 lbs of stuff in the Grand, you will be fine.
Doug Patton
Revelation 13:16-18
Think about it...
jeeepguy is offline
post #26 of 47 Old 08-12-2013, 02:10 AM Thread Starter
Candymancan
I have a brake controller in the jeep but its broken, its already wired up via the previous owner I could get a replacement controller.. the wires run through the firewall and to the battery of the Jeep, and spliced into the wiring under the steering wheel..
My 5.9's build sheet states it has a class 4 hitch and going under the Jeep the sticker on it says its a class 4 with a tow rating of 6500lbs.. That and the previous owner bypassed the cooling system and put a aux cooler for the transmission so the Jeep has been used for towing before I just don't know how much he pulled.. and I really dunno if this noise is axle or something else.. All I know its in the rear somewhere... I wish I could get a camera down there driving on the freeway and see if I could hear it lol.. Maybe Ill sit in the cargo and have my mom drive it on the freeway and listen so I can see if its coming from the middle or sides.. All I know is its quiet at 55-60mph and starts at 65 goes away away at 75.... It only happens as the Jeep waves up and down from the road at those speeds.. and it seems to be gone when the Jeep is loaded with 4 people.. me I weigh 250lbs, with the 3 others I had like 650-700 lbs in the Jeep and you can deff tell the Jeep handles diff with that weight in It but its really quiet with a load in it.
Candymancan is offline
post #27 of 47 Old 08-12-2013, 07:34 AM
SchizophrenicMC
2016 JK Wrangler
Like someone said earlier, it doesn't matter about your broken brake controller; Uhaul trailers have surge brakes, not electrics. You'd need your own trailer with electrics to get that kind of work.
Your main problem when towing, especially with a Grand, is not the going, but the stopping.
post #28 of 47 Old 08-12-2013, 07:55 AM
somebody5788
1994 ZJ
It would be a good idea to upgrade the transmission cooler to the largest one you can fit in front of the radiator but other then that your Jeep will pull it easily.
I towed my 3k lb boat/trailer with my 4.0l
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
somebody5788 is offline
post #29 of 47 Old 08-12-2013, 07:57 AM
WhiteOut
WhiteOut's Avatar
I can tow my Jeep fully loaded on a flat deck at 70 with my 5.3 Sierra.
WhiteOut is offline
post #30 of 47 Old 08-12-2013, 07:59 AM
Kevinyj95
I have towed a 85 mustang across country with my 5.2. you just need to brake ahead. Do very slow take offs. Don't strain the tranny. Problem with this post is 1 wheel bearing is bad and slowly cutting thru shaft. 2 incorrect fluid in rear diff. The noise at 65-70 is most likely the gap between the bearing and shaft it creates an unbalaneced wheel/shaft. Which will leak from the seal then eventually snap. Leaveing your jeep on the side of the road - a tire. on the axle housing if your lucky. Adding more weight will use that bearing like a saw to the shaft. I would take apart the rear diff. RTV is cheap take a look. Look at the shafts they should be nice and smooth with no gaps. It will almost look like a factory cut lol. I took mine out and thought it was suppose to be like that the first time. Look inside the diff for issues aswell and look at the fluid glitter? metal?. It would be nice to do before you have serious issues. You will want either 75w140 or 85w140 in there anyways for towing. Call junk yards for shafts if you cant afford the new ones. The bearings are cake. maybe you will be lucky and not need a new shaft but I highly doubt it with how long you waited.
Kevinyj95 is offline
