Quantcast Could this be Crank Sensor? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Could this be Crank Sensor?
Old 02-20-2007, 10:37 PM   #1
dirt machine
I have spark.
I have good fuel pressure, 42psi or so.
It cranks fine.
It doesn't start.
1996 4.0
Replaced Cap, Rotor, Plugs.
Totally lost.
Please help.
-Daniel Deisenroth
1989 Laredo
2001 Classic
Both with cool stuff
dirt machine is offline   Reply With Quote
Old 02-21-2007, 12:57 AM   #2
yrubugn
Do you have an injector pulse? It can be checked with a noid light or by spraying carb clean into the TB.
Fuel pressure at the rail is useless without injector pulse. Cam sensor or a fuse would be the likely cause of that. Hope that helps....
yrubugn is offline   Reply With Quote
Old 02-21-2007, 05:47 AM   #3
greasefingers
1994 ZJ
No not usually. If the cps is totally dead then the ecu will not allow spark. However, if the cps is not totally dead then the engine will start and then tries to stall at idle speed.
If you have never replaced the cps before, on your 1989, then I suggest you do it now. If it is not the problem then it soon will be in the future.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Old 02-21-2007, 06:18 AM   #4
greasefingers
1994 ZJ
Go to the PDC (power distribution center) the relay/fuse panel behind the battery. Check the fuses in there.
Cheers Steve
Old 02-21-2007, 08:58 AM   #5
dirt machine
So basically, it is either the cam sensor, or fuses in the pdc? Is this correct? If so, I will get in there today and figure it out. If it can be something like the cat converter or 02 sensor, let me know. I have done the CPS on both of my 89s. It sucked.
Thanks.
-Daniel Deisenroth
1989 Laredo
2001 Classic
Old 02-21-2007, 12:08 PM   #6
greasefingers
1994 ZJ
Check the fuses first
A bad O2 sensor will not have any effect on starting the engine.
Does the Check Engine light come on for 2 seconds when the ignition key is advanced one position forward?
Cheers Steve
Old 02-21-2007, 12:19 PM   #7
2tone93zj
try the coil?
1993 Jeep Grand Cherokee Laredo
I-6, 42re, 249-->242 selec-trac swap, D30/D35
31x10.5, 3.5" IRO F>R, skids and tow hooks
Wanted: 93-95 Keyless entry fob
BUILT NOT BOUGHT #204
2tone93zj is offline   Reply With Quote
Old 02-21-2007, 12:25 PM   #8
greasefingers
1994 ZJ
Originally Posted by 2tone93zj
try the coil?
He has spark
Cheers Steve
Old 02-22-2007, 12:54 PM   #9
dirt machine
Yes, the engine light comes on for 2 seconds. We pulled codes 12 and 55. That means that the battery was recently disconnected.
-Daniel Deisenroth
1989 Laredo
2001 Classic
Glock Forum
