Cost of 247 -> 242 Transfercase Swap - JeepForum.com
post #1 of 6 Old 08-17-2009, 03:16 AM Thread Starter
EarpWJ
I have searched and haven't found cost of the 247 to 242 t-case swap, how much roughly is it going to be?
EarpWJ is offline
post #2 of 6 Old 08-17-2009, 04:12 AM
sandman
i spent around $75 between needing a new tail cone, and replacing some worn out parts like bearings seals and shift fork pads. ooh and $50 on the 231. so around $125 total. so, if your doing it your self expect to spend anything from $100 to $300 depending on how much you pay for the t-case and wether or not it needs a rebuild, most rebuild kits range from $75 to $125 depending on how complete they are. JB conversions sells the most complete rebuild kits BTW.
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 6 Old 08-17-2009, 07:54 AM
skain8
skain8's Avatar
Depends which 242 you want. The 4.0L 242's (27 spline) are readily available and cheaper than the 242HD (32 spline). When my 242HD recently took a dump, I sourced a low-mileage 4.0L 242 for much cheaper than the more sought after counterpart. Just swap the input gear from your 247 to the 242 and you're set.
Or, like Sandman said, 231's are even cheaper (and more aftermarket options), but take a tad more work to fit in a WJ.
Look into www.car-part.com for the best local jy prices.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #4 of 6 Old 08-17-2009, 08:12 AM
sandman
oohhhhh yea, not even thinking, were talking WJ here.
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 6 Old 08-17-2009, 03:15 PM Thread Starter
EarpWJ
Thanks!
Before I get any further in this, how hard is it and what is involved, I could swear I saw a thread with a transfer case swap around here but I cant find it now... This will be the first real project I have done to the jeep, only thing I have done before was the budget boost, so sorry if Im slow to catch on to what is needed...
So the 231 doesnt have full time 4WD right? So I am wanting the 242.
What 242 works with the V8 4.7L, 32 spline 242HD is best right? I see alot listed for 4.0l, but few if any for 4.7.
EarpWJ is offline
post #6 of 6 Old 08-17-2009, 07:11 PM
skain8
skain8's Avatar
Search the FAQ's for the write-up.
The regular or HD version are both stout cases. The standard 242 is better in some respects actually, considering the HD has a longer tailcone which increases the angle of the driveshaft, plus the SYE options are extremely limited for the HD version.
Like I wrote in my post, the standard 242 requires you to swap the input gears from your original case to match the tranny (input shaft is longer). Not a big deal, but depends on your skill level.
skain8 is offline
one more transfercase swap question DIRTYDAWG98 ZJ Grand Cherokee Forum 4 06-14-2011 01:38 PM
249 transfercase , swap to 231. is it possible justinspotanske ZJ Grand Cherokee Forum 48 10-22-2009 12:03 PM
transfercase swap fbfootball ZJ Grand Cherokee Forum 3 07-13-2009 10:26 PM
doing a trans and transfercase swap questions 2tone93zj ZJ Grand Cherokee Forum 0 01-27-2009 10:50 AM
Transfercase swap 5.9 Rudy ZJ Grand Cherokee Forum 2 09-19-2002 10:08 PM
