Correct bump stop for 2" BB lift? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Correct bump stop for 2" BB lift?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.comTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 03-22-2015, 06:25 PM   #1
L_Kilkenny
Specs:
4.0L
2" BB (previously installed)
31" AT's (exact tire yet to be determined)
Need bump stops replaced and off road is in the picture. Go stock length or 1" longer? If longer, does any one have a source for them? I've seen em but for the life of me can't find any today. (Stupid internet)
Thanks.
Current Jeeps: '89 YJ.(2100 Carb, Nuttered, Repaired for now),'98 4.0L ZJ 2" BB,KOR Rad. Support.
L_Kilkenny is offline   Reply With Quote Quick reply to this message
Unread 03-22-2015, 07:03 PM   #2
Myusername1674
Myusername1674's Avatar
I'd say go with 2 inches of bumpstopping, basically an inch for every inch you lifted it. Or think of it as adding an extra inch for every inch of tire size you go up. I.e. stock tires are basically 29", so for a 31" do two inches.
For the front you can use the hockey puck trick, just use two per side. Not sure where to get them from the back try rough country or summit racing.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s, Build (in progress)
My 5.9 swap (in progress)
Want your zj to be doorless in 60 seconds?
Myusername1674 is offline   Reply With Quote Quick reply to this message
